-   -   might have the record (http://forums.pelicanparts.com/porsche-911-technical-forum/1045748-might-have-record.html)
70SWT 11-21-2019 11:30 PM
...for largest A/C condenser mounted in a 911.
The PO of my '80 SC was apparently VERY into having good A/C here in Vegas. How much? Here was the auxiliary condenser mounted under the car (it was plumbed in in addition to the usual one up front):
http://forums.pelicanparts.com/uploa...1574407577.jpg
This goliath was mounted transversely under the front seat area. Its length is the width of the passenger compartment; it stands about chest high when stood on end. I wonder what it was originally built for.
I bet he was cool and comfortable!
Flat6pac 11-22-2019 04:27 AM
I nehver saw one but recall the conversation about the install and efficiency
Bruce
AG81 11-22-2019 06:19 AM
Originally Posted by 70SWT (Post 10665838)
Damn...that is of good size.
70SWT 11-22-2019 07:29 AM
Yup, here it is with the standard condenser sitting on top of it for perspective:
http://forums.pelicanparts.com/uploa...1574436459.jpg
I bet you could have used this 911 as a meat locker when all of this was operational...
GH85Carrera 11-22-2019 08:19 AM
So are you removing the AC system and you live in Vegas?
That is a big condenser. I have 4 condensers in my 85 911. The Griffiths system. It works very well.
70SWT 11-22-2019 08:42 AM
Yes; I am taking the car much in the direction of Nux's cool stone grey targa project. A lot of unneeded items including the A/C are coming out as the early stages of a lightweighting effort, while I also re-do the EFI the PO installed. See my other thread on this.
greeny27rs 11-23-2019 12:08 AM
I think that’s part of a system made by Performance Aire who were in Anaheim.
I have a complete system in my loft that I had on my RS 25 years ago.
It was a bit of a problem with low suspension but got the temps down cold enough to see your breath in the car!
It had to be taken off in the end as it would only work with R12 gas.
Replaced with excellent Griffiths system.
Nick
madcorgi 11-23-2019 01:40 AM
You'd have a rolling meat locker with that thing.
eastbay 11-23-2019 09:37 AM
Back in the day they were marketed as "Desert Duty."
rattlsnak 11-23-2019 01:05 PM
My last project car that I bought had TWO of those mounted underneath!!! I do remember them being about waist high though, so maybe a foot shorter than yours, but TWO of them!! Those things weigh @ 50 lbs each also!
70SWT 11-24-2019 03:37 AM
I thought the Desert Duty condensers were just bigger front condensers - see:
http://forums.pelicanparts.com/porsche-911-technical-forum/483803-griffiths-next-generation-front-condenser-75-thicker.html
I recall looking into these options in the 90s with my first 911, in which I was roasting in the summers back in humid NC.
The whopping unit on my current project should be called Death Valley Duty.
