Inexpensive Cup Holder
Couldn't find a cup holder to clear my seat-mounted fire extinguisher so paid a visit to Lowes and bought a 3" PVC pipe connector and 3" pipe hanger. There's a small ridge inside the connector which I removed with my Dremel tool (not really necessary but I wanted to accommodate as wide an array of cups and bottles as possible). Cut the hanger to the proper length, painted everything black and bolted to body seat track. The pipe hanger can be easily bent to the proper contour and height. Despite how it looks in the photo, the cup doesn't interfere with the shift lever. Total cost about 4 bucks and some rattle can paint I had in the garage. Not as "trick" as the laser cut ones but it works.
Old 12-09-2019, 01:47 PM
Send a message via ICQ to AirJose
...Now, that is creative and doesn't look bad either!
Jose
Old 12-09-2019, 02:26 PM
I like it,nice ingenuity .
78 911 st backdate
87 944
00 996
Old 12-09-2019, 03:08 PM
1988 Carrera
shadowjack1's Avatar
What a great idea.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 12-10-2019, 04:25 AM
4flyboy's Avatar
Now that's pretty dang cool!
Drop your hand down from a shift.....gulp.......replace.....downshift....bam
Scott
"Houston, Tranquility Base here, the Eagle has landed"
Silver 1984 M491 Sunroof Coupe
Old 12-10-2019, 04:30 AM
911tracker85's Avatar
I need one to hold THIS...
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 12-10-2019, 05:04 AM
Flojo's Avatar
Originally Posted by SCforme View Post
Couldn't find a cup holder to clear my seat-mounted fire extinguisher ...Not as "trick" as the laser cut ones but it works.[/img]
thumbs up for the "I have to find a way no matter what" solution... and I like it. the idea is cool.
though you could mount my lasercut cupholder simply on the right drivers seat rail... unless you have a really tall bottle no cup or mug will interfere with seating comfort.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 12-10-2019, 10:45 AM
Banned but not out, yet..
RSBob's Avatar
Such a range of creative ideas. Mine cost $8. Slightly modified bicycle water bottle cage attached to an L bracket. Took about 5 minutes, and looks it, but it holds a range of size cups and bottles very securely.
Old 12-10-2019, 10:34 PM
Bill Douglas's Avatar
There was this strange electrical thing between the seats that didn't do anything, so I removed the big knob on the top and cut it open a bit. Works well and looks kinda factory
Old 12-10-2019, 11:06 PM
Perpetual Reassembler
2jmotorsports's Avatar
Ok please explain...
Jose - 1983 911SC Coupe
Instagram: @joe_engineer
911 D I Y Blog: joe-engineer d o t c o m
D I Y Vids: https://www.youtube.com/joeengineer
Old 12-11-2019, 07:22 AM
SCforme, VERY creative. I like it!
Careful what you wish for...
Old 12-11-2019, 08:52 AM
Driver
Noah930's Avatar
I just lay a roll of duct tape on its side in the passenger footwell.
Love the ingenuity of the OP, though. Looks great.
1990 Black 964 C2 Targa
Old 12-11-2019, 09:24 AM
Thanks for the compliment nvr2mny. Happy to hear some of you like it.
Old 12-11-2019, 01:29 PM
I removed the strange electrical thing as well. This is my solution, its actually a pencil holder from the dollar store...
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 12-11-2019, 04:13 PM
rebuilding my 3.3 turbo engine and had to get a new set of P&Cs. so made a coffee/beer mug from one of the cylinders. had to fab the black brackets.
if I put it in the freezer for a while, pour in two bottles of beer and it will turn the beer into a frosty....
Bob Cox
Old 12-12-2019, 05:49 AM
Thread Killer
Teutonics's Avatar
Bottom is welded up?
Allen
'85 911 Coupe
'75 BMW 2002
'02 Ducati Monster 900ie
'18 GMC Sierra Denali 6.2L 4wd
Old 12-12-2019, 06:11 AM
I like yours, it breathes.
A great place to keep hot coffee. Doesn't get bumped or knocked over. Handles light to moderate g forces. If it spills (heaven forbid) it doesn't land on her perfect white pants.
Old 12-12-2019, 08:53 AM
no, just plexiglass bonded. first try I used JB weld, but the heat/cold process of the freezer caused that to crack and leak. so went to a non-hardening adhesive. dont have a pic showing that.
Bob Cox
Old 12-13-2019, 05:53 AM
Registered Minimalist
75 911s's Avatar
I have the same cupholder from Spadescustomz and fire extinguisher mount from Rennline. The Rennline mount has additional holes where the extinguisher can be moved laterally toward the passenger door one set of holes. This allows you to use the cuholder in the passenger seat along with the fire ext.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 12-14-2019, 03:51 AM
