Bobasaurous, your sister sez that this is what happens when you decide to take the, "by the time I'm 80 years old" route to repairing your poor Targa! I told her that's a mean thing to say, but you know how she is! :eek:
Control pressure stone cold 57 PSI with outlet side draining into a can. |
WUR-090 batch.......
Bob, I am back home and will be testing and calibrating a batch of WUR-090’s this week. Pull out your WUR and send it to Philadelphia. You could have it back within a week after I received it. Merry X’mas and Happy New Year. Tony |
But hey, go for it and post some pics. I'm sure Raw' can learn something from them for his CIS system ! |
I dropped the WUR in the mail today to Tony. I don't trust my gauges to calibrate and I tend to lose smaller stuff if pulled off task. |
CIS sux!!!
And thanx for the compliment, brother Bobasaurous! |
Two takeaways for me are the scientific states of fuel to avoid with CIS: :D DB (Deep Brown) or PDB (Pretty Damned Brown) |
My accounting degree speaks for itself. Thank you for the recognition. |
WUR-090 test and evaluation.......
Bob, I did the tests and your old control pressure was 38 psi. @68°F and WCP @ 54 psi. CPP spec @ 68°.........29~35 psi. WCP spec..................49~55 psi. The rain and bad weather here Philadelphia has prevented me from sandblasting your dirty WUR. I want it to look nice and clean when you get it back from me this week. The problem is the micro screen filter is clogged and coated with some sort of varnish causing flow restriction and eventual high pressure reading. Tony |
| All times are GMT -8. The time now is 09:01 AM. |
