testing for a current draw with 2 batteries
I'm pretty certain I have a current draw on my '69E, but to be certain, I want to know if it matters which battery you work from? It doesn't seem like it would, but i wanted to check. thanx. steve
hi Steve ,no,it does not matter where you check...
Ivan |
thanx so much, Ivan. s
You need to disconnect the other battery if you're going to check for current draw.
Connect an ammeter in series with its ground cable (B) to measure parasitic current. Sherwood |
OK, thanx guys, i had no idea, so i'm glad I asked! I've done this test before, but not on a two battery system.
can someone explain the science and reasoning for dc'ing the non-test battery? thanx s
Wiring is like this. Ground Connection -|--BATTERY 1 (Driver Side) ++++|+++LOADS Ground Connection -|--BATTERY 2 (Passenger side)+|^ you have 2 separate ground connections. If you only measure at one, you will have current flow at the second as well. |
OK, i got it. thanx so much. s
| All times are GMT -8. The time now is 12:18 PM. |
