Who rebuilds Weber Carbs for a 73t
The newest thread I can find is from 2013 and the few I looked up are no longer in business. So I would like to find a top notch guy who can make them look new again while making them work.
Thanks in advance for any replies!
Steve 91 964 turbo 81 ROW 911SC 11 997.2 |
Paul Abbott performance oriented username 1quicks
Oops..... I see on his website he is declining new business.
Yep, already looked for him....Thanks
I would reach out to Paul. I think he is taking jobs on a case by case basis. Worth a shot.
Vintage Owner
I think his backlog is so long that he’s trying to catch up.
84 Targa (sold) 70 914-6 (sold) 73 914-6 2.7 conversion (sold) 75 GMC Motorhome (sold) 2016 Cayenne |
Insert Tag Line HERE.....
nothing hard about them. Do them yourself!! We're here to help if you have questions!
Marc |
Vintage Owner
Only rebushing the throttle shafts is tricky, but they have to be carefully cleaned and synced to run right.
Henry at Supertech Performance does a nice job as well
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
Thanks everyone. Will reach out to Henry.
very happy when Paul did mine but this is another option
https://eurometrix.ws/
-Vinny 1983 911SC |
Eurometrix.
Matt is local to me. |
DIY is not too difficult. Just taking care to clean and keep track of everything. I did mine last summer and the result was marked improvement. Depends a lot on the shafts.
I replaced the teflon bushings on the shaft ends and it helped quite a bit, but still had some leakage at other journals so I decided to re-shaft them. Re-shafting is the point of no return of a rebuild though. It requires a special piloted reamer and preferably a lathe. Here's a great video on the process: (it's for an SU carb, but the process is the same for a weber): https://www.youtube.com/watch?v=Yeu-t9ojtBc&t=531s Good luck and lots of helpful people here either way you go. Karl |
I would rather be driving
Go see Mayo Performance. They are local in Euless.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
