IAN IAN is offline
Ignition timing for 72T.. should vacuum hose on distributor be on or off??
Anybody help me out?
Should the vacuum hose on the distributor be on or off on a 72 T 2.4 MFI 911??
Thanks!!!
Old 04-01-2003, 04:22 PM
Warren Hall Student
Bobboloo's Avatar
5 deg ATDC @900rpm + or - 50 with the vacuum attached.
Bobby
_____In memoriam_____
Warren Hall 1950 - 2008
_____"Early_S_Man"_____
Old 04-01-2003, 04:56 PM
that's a retard, so it can be unplugged. if you do that, then set the timing at full advance to the farthest notch to the right of Z1@ 5000 rpm (the timing SHOULD be fully advanced at 5K). if it pings, retard it a couple of degrees until it doesn't. the idle speed may have to be turned down if the retard is not used, but the idle will sound better with the timing advanced a bit.
206 637 4071
Old 04-01-2003, 05:25 PM
Early_S_Man's Avatar
Porsche Crest
Ian,
Check this thread for complete specs and discussion of distributor maintenance:
http://forums.pelicanparts.com/showthread.php?s=&threadid=5432&highlight=distributor+lube
Warren Hall, Jr.
1973 911S Targa ... 'Annie'
Old 04-01-2003, 05:33 PM
IAN IAN is offline
Walker, which notch on the fan pulley at 5k?
I'm not quite sure which notch you mean on the fan pulley at 5k.
Thanks.
Old 04-01-2003, 05:35 PM
Porsche Crest
Warren Hall, Jr.
Old 04-01-2003, 06:06 PM
Warren Hall Student
Bobboloo's Avatar
What's the advantage to setting the timing at full advance? Is it because at full advance you can ascertain the most complete burn before the onset of detonation?
Bobby
Old 04-01-2003, 10:10 PM
