Part # needed (84' 911 3.2)
I am looking for the part number (or name) of the copper tube/rubber boot that run from the venturi to the intake elbow.
This looks like it could be an expensive part and I have seen where people have cut off the the crimped section and replaced the rubber with some tubing/hose clamps. I am hunting a vacuum leak and that piece of rubber is torn. However after smoke tests it doesn't seem to leak there. It is leaking between the airbox/MAF, getting a new gasket for that. Thanks! |
Take a look at PET Illustration 107-00. It should be part 24 or 24A.
24. 930-110-328-03 24A. 930-110-328-05 |
Download the PDF PET parts Katalog here
https://www.porsche.com/usa/accessoriesandservices/classic/genuineparts/originalpartscatalogue/ |
Thanks guys! It was this part:
https://www.pelicanparts.com/More_Info/93011032803.htm?pn=930-110-328-03-OEM |
Hi. I ordered this part a few years ago. Expensive! I searched all the Porsche sites until I found the best deal. Mine had the same problem. But before your order I heard from a very experienced mechanic on pelican to put shrink wrap on the rubber section and heat up. Leak fixed!!!!save $200!
Try it!
| All times are GMT -8. The time now is 06:40 PM. |
