solid oil return tubes or 2 piece
I have the 2 piece oil return tubes on my 930.
starting the rebuild soon. should I use the one piece ones cant find the smog pump plugs that go in the heads except at Patrick motor sports. $30 for the plugs which is ok but $20 for shipping
86 930 94kmiles [_ _] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD88 BMW 325is 200K+ SOLD 03 BMW 330CI 220K:: [_ _] RUNNING: [__] NOT RUNNING:01 suburban 330K:: [_ _] RUNNING: [__] NOT RUNNING:RACE CAR:: sold Last edited by T77911S; 12-10-2019 at 07:22 AM.. |
Stranger on the Internet
You likely have 2 piece because there once was a leak. I personally would use the factory one piece.
Patrick E. Keefe 78 SC |
One piece, and use 1/8" hex head pipe plugs for the air injection ports.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 12-10-2019 at 07:35 AM.. |
pipe plugs?
from where. any kind of locktite oin them are the cheap one piece ones from here ok. all 4 of mine were collapsible. I do like the looks of the one piece better. getting minor things together for my rebuild. almost all machine work is done. waiting on case and some other parts to be cleaned. got the heads back and the plugs were removed. twin plugged and ported to 38mm
I have hex head plugs on mine. I believe they are 1/8 MPT, as JW says.
are the cheap one piece ones from here ok. Yes, but there is no such thing as cheap
Pipe plugs are tapered so they bind up tight and the thread size is real close to the 10 x 1.0 in the heads. Any decent hardware, auto parts or plumbing store would have them. Hex head brass, not allen or square head. Used them forever. No sealer needed.
just wanted to make sure you were talking about hardware store plugs.
Targa_PB_78_SC
![]() Oops on the one piece return tube.
BareRearedRookie |
