Heated seats for 02 C4S
Guys
I bought car from Texas so no reason for heated seats but up north for sure.
Does the standard wire harness have wires ready to run to the seats.
And then can I just get the heated seats components and add to my standard seats ?
Then of course change the dash panel to activate ..
Has anyone does this
Thanks for assistance
Frank
Gold71
Old 12-10-2019, 10:36 AM
Carl v S
carlvs's Avatar
There is a thread on Rennlist with a very detailed post outlining all you’d need to do to install the factory version. Expensive... here is a list of parts fr9m that post.
Tip Tip: When ordering wires and connectors, get a couple extra. Chances are your local Porsche parts department does not stock these items. Considering how inexpensive they, it's better to have a couple on hand in the event they are damaged or misplaced than to wait 3-4 days for a replacement.
Qty.Part NumberDescriptionCostNote
2996.618.521.00Control Unit Seat Heater (Relay)$52.47
2996.612.540.01Wiring Harness Seat Heater$26.31
2996.521.531.01Foam Part Backrest Cushion with Heating$96.30
2996.521.521.01Foam Part Seat Cushion with Heating$203.90
2996.618.531.00Support Control Unit (metal bracket)$7.73
2999.591.712.40Plastic Rivet 6,0 x12, 0$0.22
2996.613.152.00.A02Tip Switch Seat Heater$20.40A02 is color code
1999.650.109.40White Female Electrical Switch Connector Housing$2.96
1999.650.035.40Black Female Electrical Switch Connector Housing$1.88
10999.650.330.00Electrical Connector (Female spades to tip switches)$.46
3000-979-008-AElectrical Wire/Connector (Small square to seat)$2.05Audi. Cut in half to make 6.
1000-979-227Electrical Wire/Connector (female blade to fuse)$2.75Audi
1000-979-117Electrical Wire/Connector (female bullet to seat)$2.10Audi. Cut in half to make 2.
1999.650.320.22Contact Bushing (to relay BS15)$.16
1999.607.060.00White 25A Fuse
Note Note: As you can tell by the part numbers, many components are shared between the Boxster and 996. Keep this in mind if you decide to look for used parts.
Carl v S
Old 12-10-2019, 11:06 AM
Carl
Wow.....great details .. just as needed.
Thanks for efforts to post
Regards
Frank
Gold71
Old 12-10-2019, 04:50 PM
Carl v S
carlvs's Avatar
And another option,
Look at this up on eBay.
4x Car Seat Carbon Fiber Heated Cushion Seat Heater Pad 5-Level Switch Kits
Carl v S
This is what I did in my 99 996 Cabriolet.
Old 12-11-2019, 04:50 AM
Thank you....will check those out.
Gold71
Old 12-11-2019, 06:50 AM
