71 911 E oil tank..how to clean?
I’m going to be cleaning 40+ years of muck off my oil tank. What is the best way to thoroughly clean inside and out. I would prefer to do it at home.
Old 12-12-2019, 07:41 AM
Functionista
manbridge 74's Avatar
Since nothing is really fragile about these maybe consider a radiator shop to do a light boil out. Here, I would clean it in a parts washer, then steam pressure wash, then into the ultrasonic tank. The rubber gasket piece is easily replaced.
Jeff
74 911, #3
I do not disbelieve in anything. I start from the premise that everything is true until proved false. Everything is possible.
Old 12-12-2019, 08:50 AM
76 911S Targa
I have used diesel fuel in a spray bottle to loosen the gunk on the outside of the tank, then steam clean with my home steam cleaner. I think a pressure washer would work equally well. For the inside I slosh gasoline, a quart or so at a time, then pour it out into a container. When it comes out clear I am done. Then air dry in the sun outside. To finish, I sanded off any loose paint to bare metal and painted with trusty Rustoleum Black.
76 911S, 2.7, Bursch Thermal Reactor Replacements, Smog Pump Removed, Magnecors, Silicone Valve Cover Gaskets, 11 Blade Fan, Carrera Oil Cooler, Turbo Tie Rods.
Old 12-12-2019, 12:19 PM
Under the radar
Trackrash's Avatar
I used a short length of chain inside my tank with the gas. When sloshing it around it loosened a bunch of crud.
Gordon
'71 911 Coupe 3,0L outlawed
Old 12-12-2019, 01:34 PM
Just keep in mind that the oil in the tank, and any unwanted debris, goes straight to your main bearings un-filtered. The filtering is done on the return trip to the oil tank.
You want the inside of that tank to be very clean...
1978 SC Targa
Old 12-12-2019, 02:05 PM
Thank you so much for all the suggestions
Old 12-12-2019, 07:51 PM
The chain and gasoline worked great!
Old 12-12-2019, 07:52 PM
