Question Thinking of Buying a 911 2.7 targa 1976
Hi Guys,
I am thinking of buying a 1976 911(?) 2.7 Targa.
From the reading I done so far, I see that I should be
looking to see if its had the several engine mods done to it;
1) oil feeded Chain tensioner
2) additional oil cooler
3) head studs replaced, or inserts fitted into case
4) pop off value on air intake.
My question is, can you pick find these out via a visual inspection,
especially # 1 & 3 ??
If so any pictures would be great.
Mileage & service history (if any) is unknown at present,
as I can't get to see it until the weekend.
Thanks in Advance
Nick Freke
924s 1986
Old 04-10-2003, 01:12 AM
thrown_hammer's Avatar
Nick,
You can tell the pressure fed tensioners by little oil lines feeding into the timing chain covers. Head studs will have to be on a receipt I think.
Contrary to popular opinion I think a 2.7 car with proper updates is a good car. Not sure but on a '76 it may have thermal reactor exhaust. If it does and has high miles I would walk away.
Keeper of the Titanium Monkey
1975 911S (sold)
1973 911 w/3.2 (sold)
1983 911SC targa (sold)
Looking for a 987.2 or 981 Cayman
Old 04-10-2003, 04:45 AM
Hi Shawn,
Thanks for the info. The comment about
'thermal reactor exhausts' is that just based on
replacement cost or other technical reasons.
Our hosts have them at about the same price as
Turbo exhaust systems. Yes very costly.
Thanks in Advance
Nick Freke
924s 1986
Old 04-10-2003, 05:07 AM
Nick,
I just noticed you are in the UK. Not sure but I think the Thermal reactors was a USA thing. They were bad for the engine because they created much unneeded heat. They are one of the reasons some 2.7's had a short lifespan.
1975 911S (sold)
Old 04-10-2003, 05:26 AM
Slumlord
Porsche_monkey's Avatar
Shawn: Don't forget to tell him to check under the back seat!
84 Cab - sold!
89 Cab - not quite done
90C4 - winter beater
Old 04-10-2003, 05:30 AM
Tim Walsh's Avatar
Send a message via AIM to Tim Walsh
Thermal reactor exhausts get VERY hot and can warp engine blocks, wear out valve guides quickly in addition to a host of other problems.
Never seen one but that's what I've heard.
Tim
1973 911T
2005 VW GTI
"Dave, hit the brakes, but don't look like your htting the brakes...what? I DON'T KNOW, BRAKE CASUAL!!!" dtw's thoughts after nearly rear ending a SHP officer
Oh yeah! check the rear seat buckets for rust!
1975 911S (sold)
Old 04-10-2003, 05:45 AM
jphillips-998's Avatar
Nick, is this a Euro car? Porsche still had a few type 83 engines with MFI laying around in '76. I think they sold about 125 of them early in the run.
Jeff
'04 Cayenne S Hauler
'98 993 Cab
'74 Euro Carrera - SOLD
'91 944S2 Track Car
Old 04-10-2003, 05:53 AM
HI Guys,
thanks for the info about exhausts.
Is it practical to replace this type of exhaust with anything ??
The car is a UK import (LHD), I don't know from where, again
I will find out this weekend.
Do the rear seats/pads come out easy to check for rust ??
A warped crank case should be easy to check via any oil leaks,
yes ???
Thanks in Advance
Nick Freke
924s 1986
Old 04-11-2003, 02:14 AM
