Troll Hunter
NOS Bosch Spark Plugs W7DTC
I found 6 of these plugs, brand new and still in their boxes, in the glove compartment of my 72T. They're called Bosch Super Cu-Electrode and have 3 electrodes instead of just one. W7DTC is the number, .80mm.
Can't seem to find out if they're compatible with the car, and they're discontinued. Plus, no clue how I would gap these with three electrodes.
Anyone?
Thx!
Nick
1978 SC Coupe, Gris Argent Metallic Silver
1988 FJ62 Blue/Gray
2020 M2 CS
Old 12-24-2019, 06:04 AM
Troll Hunter
pic, sorry.
1988 FJ62 Blue/Gray
2020 M2 CS
Old 12-24-2019, 06:06 AM
Flat Six
Flat Six's Avatar
Bosch plug decoder:
W = 14mm x 1.25
7 = Heat Range
D = 19mm reach, 17.5mm thread depth, 3mm plug tip protrusion
T = Triple electrode
C = Copper
Multi-electrode plugs don't get gapped in the traditional sense; factory pre-gapped.
Cross-references to Denso W20EPB and NGK BP6ET; looks like typically used on 80s to early 90s VAG 4/5 cylinder applications.
Hope this helps.
Dale
1985 Carrera 3.2
2013 Audi Q5 2.0T / 2005 BMW 325ci
Old 12-24-2019, 07:24 AM
Troll Hunter
That seems like it's not compatible. Crap
1988 FJ62 Blue/Gray
2020 M2 CS
Old 12-24-2019, 08:15 AM
plugs
They are ok for your car with MFI.Work very well with MSD-6A ignition.
Old 12-24-2019, 08:29 AM
Troll Hunter
Thanks Fred, but my car was built to RS Specs and has Webers. I pulled Bosch W7DC's out of it.
Still ok?
1988 FJ62 Blue/Gray
2020 M2 CS
Old 12-24-2019, 09:55 AM
NGK BPR7EIX is a better plug, unless you are burning oil. These are the Iridium tip, you can use their copper plug too, less expensive.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 12-24-2019, 03:07 PM
Flat Six
Flat Six's Avatar
Still ok?
W7DTC is the triple-electrode version of the W7DC you pulled out
Dale
1985 Carrera 3.2
Old 12-24-2019, 03:23 PM
