Front Strut Mounts
Anyone else replace these as a wear item? I have the originals but since they are 32 years old I'm wondering if they help with ride quality and handling...
Any rubber bushing will wear in time... especially after 32 years.
From a priority point of view, the top strut mount bushings are the least "important" compared to other bushings for good handling. You get two-piece inserts on the market to refurbish the mount after cutting out the factory one-piece rubber. Taking the mount out though will require a re-setting of camber and toe. |
Likewise if the upper mount has obviously failed, then you probably would replace the rest of the rubber bushings since they won't be far behind and you can then do a single re-alignment. Mark |
| All times are GMT -8. The time now is 10:10 AM. |
