What should the Point Gap be for a 72 2.4 T?
A few quick ignition tune up questions:
1) what should the point gap be for a 72 2.4 T 2) Is it necessary to lube the points anywhere? 3) How about distributor lube? Thanks, |
1. 0.014"/0.35 mm
2. Lube the cam & rubbing block with Bosch grease 3. SAE 20 engine oil or 3-in-1 oil on the felt plug under the distributor rotor Full '72 - '73 spec book data & discussion here: http://forums.pelicanparts.com/showthread.php?s=&threadid=5432&highlight=distribu tor+lube |
| All times are GMT -8. The time now is 01:44 PM. |
