-   -   Fan Housing / Alternator Depth (http://forums.pelicanparts.com/porsche-911-technical-forum/1048524-fan-housing-alternator-depth.html)
roblav 12-29-2019 08:10 AM
Before I order a new 75A alternator, does anyone make a spacer to go between my 50A alternator and the deep version fan housing? Should be about 9mm.
1987 Porsche 12-29-2019 10:03 AM
So I had this same issue on my 78 911. The previous owner installed a 50amp alternator and the alignment between crank pulley and alternator pulley was not correct. When researching this I saw this spacer:
http://www.***********/store/alternator-housing-spacer-11mm-for-use-with-930-106-000-98.html[/url]
But decided to just get the correct 75amp alternator.
Lou
1987 Porsche 12-29-2019 10:05 AM
Website is allzim .com
roblav 12-29-2019 11:04 AM
Thanks Lou! $75 bucks! I think I'll do the same as you and buy the new 75A alternator.
Jonny H 12-29-2019 11:07 AM
We do. We also have a modern 175A unit that is a direct fit to an early car. Later cars use the spacers.
Flojo 12-29-2019 11:13 AM
175 ?!
why'd you neede that?
Jonny H 12-30-2019 01:32 AM
Originally Posted by Flojo (Post 10702156)
175 ?!
The 175A alternator was developed to allow our electric AC to run at full potential. It also opens the door to electric heat which we are working on. There are also a lot of ‘retro mod’ builders adding extra toys to the cars. Nose lifts, power steering pumps etc, heated seats etc.
The original Porsche alternators have very poor idle output, the 90A unit only only do about 35A, ours is 75A.
