SC window switch repair goes smokey
SO:
I decided that I would take a shot at aligning my windows on the targa, so that I could at least eliminate a little bit of the wind noise at speed that is not created by the rest of the mess (thank you for the posts, Dan of Carsinc). Along for the ride, I figured that I would try to get the window switch wiring connections more secure; because the various POs were a little sloppy about using shrink tubing where it needed to be replaced over the years. What I did not realize was that I had a bit more of a science project to tackle (that I am glad that I caught NOW. The power (window) wires that go into the door from near the A-pillar were getting pinched at the hard stop (more on that later) and I put together my "completed" project ready for a test. I connected the battery, turned the key, and saw smoke pumping out of the A-pillar door jamb, near the hinges - meaning that bad things happened. After I nearly injured myself running to disconnect the battery and grab one of the 4 fire extinguishers in the garage, I knew that I had a bit more of a project to tackle than previously forecast. Once the smoke cleared (literally) ... and after fighting with the wiring, I was able to pull it back through the butt side of the door, I realized that I uncovered a mess that has been brewing for a while. Enjoy the pictures; thankfully I did not have a car-b-q to bring in the new year.... Anyhow, I did a cursory search in the parts section of the host's catalog --- What is the black part that (I believe) goes on the end of the door stop?
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things. |
I looked in the "PET" and it does not show that black part that (I believe) goes on the door stop. Does anyone know what this part is? I would hope that the host has one....
Still here
It's probably part of the harness.
The center of this plastic part has a square cut out, I am pretty sure that it was supposed to be connected to the end of the door stop. Perhaps it is a little piece of foam, or a soft-stop on the mechanical door stop.
I will take another picture of it when Im back in the garage... I think that the wire harness (when I look in the PET) is just 4 wires, a covering, a seal for the door-pass-through and the round 4 pin connector on the A-pillar.
I had the same situation on a 1985 only a lot more wires, mirror, window, speaker. All had been wearing over the years. I ended up replacing and reinforcing the door stop and while I had the door off I unplugged the harness near the A pillar in the trunk and repaired the harness where it flexed in the door, sorry no pictures.
Yeah; I too have the speaker wires, as well as the power mirror wires, so there's no doubt it is a mess of "hot" wires going in there that were wore down to nothing...
I decided to just replace that wireharness: man, you want to talk about a porsche tax.... I decided that it would be a better move than soldering in wire to be a cheap-ace, and then have potential problems down the road (did I mention that I am not a fan of removing the door panel?). Also, this way: I can sure up some other things inside the door that have been lingering. I suppose this way: I've paid the tax to ensure things are not going to burn to the ground when I attempt to roll the windows back up on some unsuspecting summer drive. ... at least not from THIS circuit. The little block that is broken: here's another picture. I got into the passenger door and confirmed that this is a little foam/plastic block that goes on the end of the door stop, perhaps to soften the blow of a "hard" stop against the full opening position. It's not in PET. Anyone out there know what htis thing is called so that I can attempt to buy one? Or, am I off to the shop to try to make one?
Still here
Why would the wiring wear out to nothing in that relatively benign location, heatwise, unless there have been previous shorting incidents ? If it's somehow age related, I would worry about the wiring throughout the car, probably not the only place where it has worn down.
"Why would the wiring wear out to nothing in that relatively benign location, heatwise, unless there have been previous shorting incidents ? If it's somehow age related, I would worry about the wiring throughout the car, probably not the only place where it has worn down."
My statement about wiring was kind of a joke on my end. In this instance, the wires were getting pinched against the hard stop for years without my knowledge, and finally we had an incident. As I am going through this car in bite sized chunks over the years, I am noticing that there are other areas that COULD have been left like this for years.
Does anyone know what this door stop thing is?
