WUR Rubber Fuel Line Replaceable?
My original rubber/braided hose (unable to tell which at this point) from on the WUR side of the line is turning to dust.
Replacing the entire line including the metal seems irresponsible at the $100+ price point. Is it possible to just replace this section? Anyone know the correct hose parameters? |
Picture would help........
Fizh, Not sure if you were referring to the fuel line or the vent line for the WUR. Could you post a picture of the said line? Thanks. Tony |
The disconnected rubberish hose, which eventually connects to a metal line and that connects to the fuel distributor mixture.
![]() https://i.imgur.com/pMnNztG.jpg Last edited by fizh; 01-05-2020 at 11:32 AM.. |
![]() If this is what you are referring to I can help... ![]() You do not say what year & model you have, but this is for a 80-83 911SC and is the FD to WUR Line. I can Re-Make this (and most of the other CIS lines) for a LOT less than you mention, but you must send this to me, as we can only buy the assembly from Porsche, and pretty soon not even that. Please, email only. Len dot Cummings @ verizon dot net
![]() To clarify, I replace the Line/Hose on your original Hardline. It can also be sent out for Yellow Zinc plating if desired. For details, please email me. No pm's as I cannot send photos via pm and my box is almost always full. Len
