-   -   More power window switch weirdness (http://forums.pelicanparts.com/porsche-911-technical-forum/1049310-more-power-window-switch-weirdness.html)
M491Cabriolet 01-07-2020 04:31 PM
Hi all. I’m having a hard time figuring this out. On a mid year 911, the passenger window goes up and down only if/when I swap the positions of the green and black wires on the passenger door switch (with each other). Leaving the wires in one place, the window will only go down. Swapping the wires, the window will go in the opposite direction. The driver door’s passenger window switch has no effect. The driver door switch works fine.
My switches are new German parts and are wired like this:
http://forums.pelicanparts.com/uploa...1578443235.jpg
I’m no guru on electrical issues, so any help will be highly appreciated. Thank you!
Drymartiniwi 01-07-2020 04:45 PM
To me sounds like a bad switch
M491Cabriolet 01-07-2020 04:46 PM
I’ve tried moving the switches around... no love.
Hotshot 01-07-2020 06:31 PM
I just had to sort out the switches as I had my door cards off and I forgot what went where. You should have a red/ w wire, a blue/blk, blue/brn, red black, brown. I’ll grab my book where I sketched it in. Copy what I wrote. I have the 2 drivers side and the pax
I know the top ones red.
M491Cabriolet 01-07-2020 06:34 PM
Hmmm. I have red, red/black, red/white, green, black and brown.
sky1jord 01-07-2020 09:05 PM
This might help, good luck
http://forums.pelicanparts.com/porsche-911-technical-forum/767956-window-switch.html
Hotshot 01-08-2020 04:58 AM
What I was going to show you is exactly ^ post
AG81 01-08-2020 06:07 AM
I just went thru this....... bad switch.......needed to replace all three......and I had what M491Cab has also...........
