Super Moderator
cstreit's Avatar
Main bearing 72-3429 0.25mm UST What is this?
Is that for a line-bored case? ...or a ground crank.
Can't seem to find out a reference...
Chris
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 01-08-2020, 01:40 PM
Measure the OD if you have them in hand. Rubber band the #1 thrust halves together and mic them. You would notice 0.10 thou oversize, or thereabouts. Usually stamped on the bearing too.
206 637 4071
Old 01-08-2020, 05:14 PM
Super Moderator
cstreit's Avatar
I’m getting 64.96mm
I think that makes the STD OD and undersized ID yes?
(It’s for a 3L which has 65mm mains.
Old 01-08-2020, 06:13 PM
Sounds like it. OD oversize is not common. Expensive too.
206 637 4071
Old 01-08-2020, 07:52 PM
