Engine rebuild or swap? What would you do? ('79 sc)
Hey fellow Pelicans!
My '79 SC has about 124000 miles on the clock and I am considering a rebuild in the next couple of years and I am curious to everyone's thoughts here. My options are:
My mechanic is telling me I need to have $25-30k for a rebuild. I am new to 911's having owned this car as my first for just 2 years. I am about to go through Wayne's 101 list of oil leaks, upgrade to the turbo chain tensioners, as well as potentially fitting SSIs and and M&K Active Exhaust to accommodate a 3.2 rebuild next year, but if a rebuild is this much I need to start thinking and saving for this now. Another option I have been wondering about is that if a rebuild is gonna cost me $30k companies like Vertex Auto are selling rebuilt engines for $15-18k and should I not just go that way and send in my core to them which would bring that down to around $12k (for a 3.2). So I guess my questions are:
Thanks as always everyone!! Dan |
Wow! I would get a second opinion! That cost seems kind'a high!
why does it need a rebuild.
you could do valve guides/top end. that engine has a very good bottom end on it if oil pressure is good. price seems very hi to me too. |
There was (maybe still available) a 930 turbo engine for sale on Pelican for $23,000.00 US, which is a bargain, especially if you compare those rebuild prices. I'm from southern Ontario & can tell you pricing is always a little high in Ontario to begin with, but you have options so try not to rush into any harsh decisions.
First, is that CAD or USD? Big difference as you know.
Second, is that a TOTAL rebuild? Better be for that $. Third, why is he recommending a rebuild? What are the symptoms? Oil leaks don't always spell rebuild. They can be fixed. Fourth, I'd get a second or even third opinion. Fifth, if everybody is on the same total rebuild page(which I highly doubt), I'd shop the hell out of it. At that price you can buy and entire SC. I'd even consider shipping the car to the states for the right shop. Lastly, there's only one shop I'd consider spending that type of money with and they're local and extremely well known, experienced and have a great reputation. They better. That's a lot of dough and a big job. SC's can last a lot longer than 124K miles without a total rebuild. Top end rebuilds are sometimes required, but they're $7-9KUSD. I smell fish. |
Dan as the boys said get a second or 3rd opinion..For that money i fly from Czech to you with my tools do your engine and still have the money for beer in Cayman islands beaches...;-)
Ivan |
Yea... totally agree with everyone else. I looked at the prices of modding my 3.0 (3.3 ss with ITBs and EFI) and a 3.6 swap. $25-30k you're in that territory -- not just a straight rebuild.
Thank you guys! You are helping me see the light - my mechanic is a solid dude and I trust him but he is also an absolute perfectionist and I believe this is reflected in his estimation.
The car, in my opinion, has always run really well. Oil temperature never gets too high, I don't seem to be getting through too much oil, there are (touch wood), no worrying sounds. Here are the result from a compression test that he did in August 2018: One - 155, Two - 150, Three - 150, Four - 140, Five - 150, Six - 145 I don't know how to read these yet but they are all within 10% of one another with number being 9.7% lower than number 1. This seem ok right or have I just further proved my lack of experience? ;) |
One more thing... speaking from personal experience here... the Porsche community has some top-shelf human beings. It also occasionally has some less scrupulous people. I'm gathering you're a little new to Porsche ownership. I was too almost a decade ago. In the early days of my ownership I dealt with a shop that smelled my newness a mile away and tried to take advantage of me. I'm not saying that's what is happening to you. But I certainly agree that you should get more than one opinion. And this forum is an excellent resource for level-headed advice.
You just have to be careful nowadays. |
Dan......does your 911 smoke at any point..morning or warm-hot?As you said ,it is not using oil that is good.Oil leaks are easy fix....Also , with this mileage you are just barely broken in the engine...
Swapping for 3,2 takes more than just the engine ,el.harness, computer and e.t.c. Ivan |
My goal over next 2 months will be: fuel pump replacement (it died and I have a new one shipping up here from our host as we speak), TOD oil leaks, replace both breather hoses which are wet with oil valve cover gaskets, sump pump gaskets and replace crush washers because I have a leak there as well, upgrade to turbo chain tensioners while I am at it. From there I think I'll just sit tight and see how she runs for the summer before jumping into a rebuild. I have also just done a bunch of reading on a top end vs full rebuild and if I do someday need to do this perhaps a top end only would be the way to go. |
Your trans would probably benefit from going-through @ 120K, upgrade tensioners and fix any minor oil leaks while motor is out would be my plan. Unless there's something you're not telling us. |
I definitely agree on the transmission - look what I found last night. I was cleaning the bottom of the car with some AT30 and a toothbrush and after removing 20 odd years of oil and dirt I uncovered this crack/hole right where the starter is mated to the transaxle: http://forums.pelicanparts.com/uploa...1578673870.jpg |
Dan..yes do the necessary repairs as for the oil leaks.It is quite normal for the breather hose to leak.Most of the time the hose is very hard and the clamp does not hold it tight.That can be done with the engine in the car.Clean it and see it the other things are leaking ,oil press.switch and thermostat o ring.plus eventually the breather cover gasket.Look here for Triangle of Death..plenty of help here on search button.
Yes drive it and enjoy it later you will have more knowledge about your 911... Ivan |
| All times are GMT -8. The time now is 07:22 PM. |
