T77911S's Avatar
installing exhaust/intake studs
I need to put the exhaust studs and intake studs back in my heads.
should I use locktite and which one.
I was told to use the 1/8 hex head brass plugs for the emissions ports but I cant find any
88 BMW 325is 200K+ SOLD
RACE CAR:: sold
Old 01-10-2020, 07:35 AM
I'm certainly not an expert. I used the blue many years ago to install new studs. I recently had to remove the exhaust, and yes rusty nuts, I had three of the studs unscrew with the nuts. Better than a broken stud. This time I replaced the non barrel nuts with copper clad nuts hoping not to have the rust issue. And I used the blue locktite again. It will be interesting to hear other comments.
Old 01-10-2020, 05:02 PM
fred cook's Avatar
Exhaust studs
When I rebuilt the 3.0 in my SC, I used stainless steel studs and nuts along with a light coating of anti seize cream. Now, 6 years later, they still look like new! I did use the blue locktite when I put the studs in the heads.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 01-10-2020, 05:46 PM
The 9 Store
I was told by the engine experts on this site to use regular steel, not stainless and no locktite but a high heat anti seize.
https://forums.pelicanparts.com/911-engine-rebuilding-forum/1040927-exhaust-studs.html
All used parts sold as is.
Old 01-10-2020, 05:57 PM
Targa_PB_78_SC
mike sampsel's Avatar
I got my brass at Ace hardware in the plumbing section.
For the exhaust studs into the head (for the Heat Ex), I used no loctite. I do not recall using anti-seize on the stud, but did so on the threads where the barrel nut and other nuts fasten. Thought the exhaust studs get too hot for loctite anyway.
BareRearedRookie
Old 01-11-2020, 05:01 AM
No stainless on stainless. I just crank them in tight and if one happens to come out with the nut on later disassembly, no big deal, just screw it back in.
206 637 4071
Old 01-11-2020, 06:55 AM
