Jerky low speeds 3.2 carrera
Hi All,
I have a fairly stock 3.2 Carrera with a Wong chip and M&K exhaust, when slowly creeping forward in 1st or 2nd gear the car can be quite jerky sometimes. The only way to stop this is to put foot on the clutch and coast.
It's those scenarios where I am wanting to go 5-10kph and creep forward. Is this a symptom of bad driving or perhaps something mechanical?
Old 01-10-2020, 08:22 PM
Stall speed on these engines is quite high, so yes, as you slow to a stop you have to engage the clutch early.
Eine Garage ohne Porsche 911 ist nur ein dunkles Loch - Walter Röhrl
Old 01-10-2020, 08:29 PM
I noticed the same thing. I think it's just a "that's how it works" situation.
Old 01-10-2020, 08:51 PM
Yep. It's normal. You just get the feel for when you need to depress the clutch.
-Vince
'88 Carrera Targa
'10 Carrera S
Old 01-10-2020, 09:20 PM
1988 3.2, the same. It doesn't like low revs in 1st or 2nd gear. That's why I don't like driving in heavy traffic. I always thought that the engine was loading up and I would rev to clear but it didn't make any difference.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2017 VW Golf TSI
Old 01-10-2020, 09:21 PM
Driver, not Mechanic
How low do you guys let it go? I’ve rarely experienced this, but maybe because I cut my teeth driving a Beetle...
Old 01-10-2020, 10:10 PM
Bill Douglas's Avatar
Yep.
They aren't very good town cars. First gear is very high and they don't like low rev's. Especially laboring at low rev's.
My SC tend to be "We're off, stop, we're off, stop..." etc. Hard work in walking pace traffic.
see www.lyallbaybeach.co.nz
Old 01-11-2020, 01:25 AM
Thanks all, good to know it's not just me! I had an SC prior which felt a bit better at low speeds in traffic so thought something might be up.
Old 01-11-2020, 01:27 AM
OK, and I was about to open up my AFM to try to fix this 'problem', but apparently it is normal behaviour. Very annoying anything lower than 25 km/h (15 mph) is an issue on mine (85 Carrera)
Old 01-11-2020, 02:42 AM
They have a fuel cut out when the engine is above 1300rpm and the throttle is closed that may contribute to the jerkiness. I also recall posts suggesting wear on the resistor track of the AFM makes them worse.
EDIT: Found one:
[3.2 Motronic] Air Flow Meter wiper arm re-tracked - WOW!
PS. My 3.2's have never liked low speed running either
Old 01-11-2020, 02:45 AM
My '85 was pretty bad, but installing a Steve Wong chip helped it considerably. The '88 isn't quite as bad, but it's there. No chip yet so I can't say if it'll improve.
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-11-2020, 04:34 AM
That's fond- just deglaze
Hi cafe_racer- I did notice a sizeable improvement in low-speed operation once I retracked the AFM. Here's my story...
Air Flow Meter Adjustment!
Missed Approach
Petra- 1986 Coupe
Old 01-11-2020, 05:58 AM
AG81's Avatar
Originally Posted by caitov View Post
yep. It's normal. You just get the feel for when you need to depress the clutch.
x2
Who are you? I'm the Guy!
https://www.hotrod.com/articles/1009phr-1976-pontiac-trans-am/
Old 01-11-2020, 07:40 AM
Diss Member
Quicksilver's Avatar
My 87 had issues with jerking and surging at low RPMs until I went through it and replaced the intake gaskets, intake spacers, a whole bunch of dried and hardened old rubber, and had the DME's solder joints reflowed.
Since then the car will smoothly crawl along at idle.
- "Speed kills! How fast do you want to go?" - anon.
- "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh
Wayne - 87 Carrera coupe -> The pooch.
Old 01-11-2020, 09:47 AM
So you're thinking it's more like vacuum leaks (lower rpm's, less vacuum). Would be nice to have driven a brand new one off the showroom floor to see if they had that problem. I guess if someone has just overhauled an engine, they could confirm if the problem still persists...
'88 Carrera
Guards Red
'70 VW Beetle
Yukon Yellow
Old 01-11-2020, 09:51 AM
Amateur
pmax's Avatar
Originally Posted by cafe_racer View Post
Hi All,
That's not normal. My 87 runs smooth at parking lot speeds.
I agree with the others yours might have a vacuum leak.
I don't need that.
Old 01-11-2020, 01:18 PM
NutmegCarrera's Avatar
Location: Plymouth Wi. - Spitting distance from Road America
I would not agree that this is normal. I had similar issues when I got my ‘85. Through all of the research, etc... I learned about the “Barndoor” AFM. The contact wiper wears a path in the mating piece (the air flow is measured by how far the “bar door” opens, and that position is reflected through a variable resistance (?) strip. Much like old R/C car speed controllers). By changing where the contact arm “wipes” this surface - you can smooth things out considerably.
I’m sure there are better words to describe the components I describe - but this is the experience that I had. I did find a procedure for opening and adjusting this somewhere. May have been in the 944 forum. The Motronic system uses this type of air flow measurement.
Not discounting vacuum leaks, bad sensors, and the like.
Don’t accept a car that bucks and stutters. These things should be smooth.
Good luck.
Old 01-14-2020, 10:36 AM
Does the jerkiness occur even after the motor is warmed up? In my experience, the jerkiness -- actually a pretty violent bucking -- caused by worn track in the AFM was basically a cold engine phenomenon.
I agree that your should run smoothly at low rpms.
1988 Carrera Coupe (3.2)
1976 BMW 2002
Old 01-14-2020, 11:40 AM
Diss Member
I call that whole episode "The Rubber Explosion Incident™". I found cracks in some of the hoses on the front side of the engine and the big breather hose was so hard I assumed it was made from some sort of plastic. (I was shocked to find out how soft the new hose was!) I also discovered that the crimps on the fuel lines to the injector lines were so degraded that the fittings were spinning like they were bearings. (They hadn't leaked a drop either.)
I knew the intake gaskets were leaking but when I pulled the manifold off I was surprised to find that the plastic manifold spacers had eroded too.
Fixing all of the above really smoothed it out but I also had the DME reflowed and while I was in there I replaced the 24-pin chip with the last factory 28-pin chip. That made it idle better then it had when I bought it at 110K miles back in 99. The DME needed the reflow but the 28 pin chip upgrade raised the idle from 800 to 880 rpm which would make some difference.
I really feel that absolutely eliminating all vacuum leaks was the biggest fix. It really brought it all together.
Old 01-14-2020, 12:42 PM
I had a similar issue before replacing the ICV and addressing a couple vacuum leaks.
Old 01-14-2020, 09:48 PM
