-   -   Weird problem with turnsignals on '69E (http://forums.pelicanparts.com/porsche-911-technical-forum/1049704-weird-problem-turnsignals-69e.html)
steve meltzer 01-11-2020 02:08 PM
If you signal left everything is fine. However, if you lift the turn signal stalk to signal, right, the right arrow in the gauge is perfect, but the left arrow in the gauge simultaneously flashes in very rapid bursts. Occurs with or without the engine running. The outside corner bulbs flash as they should at all times. WTF? thanx steve
roblav 01-11-2020 04:02 PM
Check grounds.
lrodri64 01-11-2020 06:03 PM
Check for grounds.
If you use LED’s also could happen
john walker's workshop 01-11-2020 06:05 PM
Try another relay. They do weird feedback things sometimes.
steve meltzer 01-11-2020 08:06 PM
I got the car about a year ago, tho' it was in the shop for about 2 months early in my ownership, getting A/C and some MFI work done, so not lots of time with the car. However, I do believe this may have occurred, occasionally, but not consistently at low RPMs, then if you revved her up, that second signal went away.
Just put in LED bulbs! and now, it is a consistent finding. So what are my options here?
Still check for a bad ground? in the gauge or the stalk, or both?
thanx.steve
AirJose 01-11-2020 09:33 PM
Hello all,
Seems like the 69 has a lot of electrical issues since it was a year only wiring. On the front or the rear? First to be honest replace the relays. Get a new flasher and the 5-6 relays and replace all. I know it sound drastic but at the long run it will solve a myriad of problems. I had two that worked on and off and it took me a while to figure it out. Small LED's will work fine in the markers(Front and rear sides) and license plate lights (BA9) in our 69's. Double filaments like 1157 are problematic. If you need other LED's I will use Spoke's (another pelican LED's system) Clean all grounds, Front grounds are attached to the square side boxes; in the rears check the rear inside area by the engine bay and behind the the light boxes. Everyone here is giving you sound advise!
Jose
lrodri64 01-12-2020 07:06 AM
I work on a 69’ 912 and I don’t have the explanation but I had to remove the LEDs.
Just try it. And let us know. Everybody is learning here.
steve meltzer 01-12-2020 07:32 AM
Irodri, would you pull all LEDs or just the ones in that gauge. I hate to have to do that, ^%$$#&$@#%*&)&%$. s
lrodri64 01-12-2020 07:43 AM
The 912 that I fixed had leds on the signal bulbs. At four corners.
I’m referring to the ones outside. Not the indicators inside (on the gauge)
steve meltzer 01-12-2020 12:14 PM
Rechecked my musings...the 4 corners are working properly...my problem is, almost certainly, in gauge lights and maybe the LEDs. thanx. s
steve meltzer 01-18-2020 12:57 PM
Pulled one LED in the tach gauge, replaced with the ancient incandescent bulb. fixed!! thanx. steve
