9Firty's Avatar
Noisy fuel pump
Need some advice with regard to a noisy fuel pump. It only happens sometimes and when it does it's a really loud buzzing whining noise. I'm not sure if the noise or the fact that it's only sometimes causes me more concern.
Do I need a new one or is this normal (probably not) or fixable (I hope so)?
Cheers
Simon
1984 Ruf 930 (gone)
2001 996TT (arrived)
2008 997GT3 (dreamin')
Old 10-31-2004, 01:25 AM
Mine was really noisy because the positive lead to the pump was grounding through the chassis due to the wire's protective sheath being rubbed off after all those years of vibration. I wrapped it in electrical tape temporarily until I rerun a new wire and the noise went away.
I'm not sure how you car is setup compared to mine but it might be something to look for before you spend the money on a new pump.
'70 911T Signal Orange
Old 10-31-2004, 01:33 AM
andrew johnson's Avatar
Hi 9firty from the eastern states.
I had an intermittant noise from my fuel pump.
My mechanic sugested that it may be simply the metal cover over the steering rack touching the fuel pump. Guess what it was!
Cheap fix.
Andrew
Andrew Johnson
Newcastle , Australia
1976, 911 ROW
no mods
previous car
Mercedes 280CE 1979.
Other car
2004 Peugeot 307
Wife's & Family Truckster
Old 10-31-2004, 01:49 AM
Has anyone ever rebuilt a fuel pump and reset the discharge psi ?
Ronin LB
'77 911s 2.7
PMO E 8.5
SSI Monty
MSD JPI
w x6
Old 10-31-2004, 07:00 AM
