Measure Front Suspension - PO Replaced Front Pan
Hi All
The PO had the front pan replaced. A workmanlike repair, solid but not pretty. Supposedly a VW guy so knew pans, not necessarily 911s. I was going to just replace it but the rest of the car is good enough it doesn’t automatically make sense. I was able to measure my TR8 via lines on the floor, plumb bobs etc with surprising accuracy, it was very accurately made. Where can I find the vertical and diagonal dimensions etc? A diagram would be really heplful. TIA! |
Restoration Design has the dimensions on their website, under the tab marked resources.
Quality Custom Porsche Panels | Restoration Design Inc. |
Great! - Now How to Decode...
Thanks werke1! This is what I am looking for. Now I have to decode what all of the X-Y & I-II-III designations refer too. I work a lot with engineering drawings but standards have changed.
I get a lot of it but I guess I must study it longer. Is there a key or 'title block' with any more info? |
For a quick check for square, you can compare measurements.
Compare the diagonals to each other and the verticals to each other. That'll tell you if your square. I "adjust" the bolts so the flats are parallel to each other, then measure flat to flat. Don't forget to tighten back up when done! http://forums.pelicanparts.com/uploa...1578925020.jpg |
Thanks guys! Very helpful! I would be measuring it up this weekend but for my in-laws are coming for a visit over the weekend. Which lasts from Thursday til Tuesday...😳😳😩😩🤪🤪
There is always NEXT weekend... 😁😁 |
Here are some clearer images of the work shop manual pages.
https://photos.smugmug.com/Cars/Pors...16_0001-X2.jpg https://photos.smugmug.com/Cars/Pors...16_0002-X2.jpg Mark |
Thanks Mark! I will update the list on what I find.
Turns out everything is within 2mm of tolerance. Good enough for me. Thanks for the help!
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
Copyright 2020 Pelican Parts, LLC - Posts may be archived for display on the Pelican Parts Website
