Measure Front Suspension - PO Replaced Front Pan
Hi All
The PO had the front pan replaced. A workmanlike repair, solid but not pretty. Supposedly a VW guy so knew pans, not necessarily 911s. I was going to just replace it but the rest of the car is good enough it doesn’t automatically make sense. I was able to measure my TR8 via lines on the floor, plumb bobs etc with surprising accuracy, it was very accurately made.
Where can I find the vertical and diagonal dimensions etc? A diagram would be really heplful. TIA!
Triplesn8s
'72 911T Coupe
'80 TR8 Convert -Selling in Spring for 911 Resto Funds
'78 TR8 Coupe - Autocross Project
'06 Ducati 1000SS/DS
Old 01-12-2020, 01:26 PM
Restoration Design has the dimensions on their website, under the tab marked resources.
Quality Custom Porsche Panels | Restoration Design Inc.
Old 01-12-2020, 06:07 PM
Thumbs up Great! - Now How to Decode...
Thanks werke1! This is what I am looking for. Now I have to decode what all of the X-Y & I-II-III designations refer too. I work a lot with engineering drawings but standards have changed.
I get a lot of it but I guess I must study it longer. Is there a key or 'title block' with any more info?
Triplesn8s
'72 911T Coupe
Old 01-12-2020, 06:52 PM
Old 01-13-2020, 05:00 AM
Home of the Whopper
BK911's Avatar
For a quick check for square, you can compare measurements.
Compare the diagonals to each other and the verticals to each other.
That'll tell you if your square.
I "adjust" the bolts so the flats are parallel to each other, then measure flat to flat.
Don't forget to tighten back up when done!
FS: '71 911E Targa rustbucket - $20k
Old 01-13-2020, 06:20 AM
Thanks guys! Very helpful! I would be measuring it up this weekend but for my in-laws are coming for a visit over the weekend. Which lasts from Thursday til Tuesday...😳😳😩😩🤪🤪
There is always NEXT weekend... 😁😁
Triplesn8s
'72 911T Coupe
Old 01-13-2020, 08:26 PM
Mark Salvetti's Avatar
Here are some clearer images of the work shop manual pages.
Mark
1979 911SC Targa
Old 01-13-2020, 09:14 PM
Cool
Thanks Mark! I will update the list on what I find.
Triplesn8s
'72 911T Coupe
Old 01-14-2020, 02:32 PM
Turns out everything is within 2mm of tolerance. Good enough for me. Thanks for the help!
Triplesn8s
'72 911T Coupe
Old 03-15-2020, 06:04 AM
