This linkage attached to my transmission.
I was working underneath the car and I found this stuff. I believe it is gas pedal related. Is there any maintenance or cleaning or greasing required? While I am down there....
1988 Carrera coupe 1966 250 Ducati 2015 VW Golf TDI gone because Dieselgate! 2021 VW Golf TSI 2014 Ninja 300 |
White grease on both ends and new bushings when they wear out. Metal ones preferably.
Yup. There is a pair of plastic bushings that are inserted into the tube. They get old, hard, crack, and should be replaced. Lube with a small smear of high-pressure grease.
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ |
