-   -   ignition buzzer help. Need clarification. (http://forums.pelicanparts.com/porsche-911-technical-forum/1050001-ignition-buzzer-help-need-clarification.html)
Hotshot 01-15-2020 06:15 AM
My alarm works as advertised. Loud. I don’t thing the ignition buzzer is that loud horn..
PO didn’t have a lot of bulbs installed, I’ve made everything back to stock and changed or added every bulb you can.
I fixed the door switches and they work as advertised, open door, light comes on.. close, goes out.
I never realized there is a buzzer supposed to come on. Looking at schematics it shows a separate buzzer on the ignition.
I also have no seatbelt light ( park break and brake wear work ). I thought it was burned out on the board but further reading on here shows it’s tied in to this relay. I’ll have to look at the Schematics in depth..
Anyway, before I pull my oil P gauge out and see if the relay is there,
If the relay is out, how I understand it is my door lights would not work at all. They do. So can one pull this buzzer?
bkreigsr 01-15-2020 12:26 PM
sure
john walker's workshop 01-15-2020 12:42 PM
Pulling off the two wire plug on the steering lock shaft is the easiest way to kill it.
Hotshot 01-15-2020 02:21 PM
I’ll have to see how the PO installed the Momo then. I looked at the circuit today and it shows a separate buzzer. Will explore.
86 911 Targa 01-15-2020 02:52 PM
Buzzer contact.
http://forums.pelicanparts.com/uploa...1579128732.jpg
Factory manual for our '86.
Gerry
Hotshot 01-15-2020 03:09 PM
Thx Gerry. I have the whole manual. That’s exactly what I was referring too.
Hotshot 01-15-2020 03:11 PM
The purple goes to the Seatbelt controller and the other black wires hit the door switches via the lights. It’s a strange run.
