Horn Grill Lights
Anyone have luck with finding decent horn grill lights? Entire kit would be nice, grills, lights, wiring. Something bright.
Like in the photo.
I make the lights and grills. Wiring is available through Kroon. Switch isn't available except for used.
I also make H1 headlights, Cibie hood mount rally lights, Hella 128 fog lights... etc. etc. Cibie Biode's are in production as well. Eric www.autoforeignservices.com
http://www.autoforeignservices.com/ 57 Speedster, (4) 67S coupe's, (2) 67S targas, 68L Rally car etc. etc. |
Eric’s lights and grills are fantastic. I used some high quality wiring and a relay with trigger tied to my high beams.
I’m Not sure what years this may be true for, but on my car the wiring from the fuse block area to the lights was already in place. Wire was wrapped up and tucked on top of battery box. The other 2 wires terminated at the bottom of the lower fuse block iirc. Feed power to that fuse via a relay triggered from a switch or some other trigger.
