dropped the Brad Penn ......
approximately 1000 miles on B P.
installed VR1 - due to perceived increased in seepage, with the semi synthetic. idle increased from 850 to 1000. didn't touch anything else. weird. |
Does the RPM change if you remove the oil cap?
slight drop - same as usual - never drops/dropped as much as i have experienced with other air cooled units. professionally smoke tested recently. supposedly all good.
adjusted idle downward - all seems fine. gonna closely monitor the weeping activity. Last edited by creaturecat; 07-12-2020 at 09:27 AM.. |
While you are monitoring things compare oil temp differences too.
Brian Miller - Scottsdale, AZ 1971 Porsche 911 T Targa @targatuesday :: 2005 Ducati Monster S2R :: 2008 Porsche Cayman S |
