Mystery sunroof part
1979 SC
Can someone tell me where in the sunroof this goes or a part number? Looked at the parts diagram in the PET and can not find it. When I took the car apart and the sunroof tracks out it was laying loose in that area. Thanks
Piece of Headliner tension rod.
Slippery Slope Expert
That is a guide pin for the rear of the sunroof track. They often come out and are found laying loose in the cavity when a track is removed.
The skinny end slides into the rear of the track; I think if you look at the rear end of the track it’s location will be obvious. Slide it into the track up to the ridge. The fat, back end of the pin goes into a hole in the rear of the sunroof assembly to locate the back of the track. The parts drawing doesn’t show this as available as a separate part but rather as part of the track. But the one you pictured is perfectly reusable. The bent part will be fine once it is inserted back into the rail. I have a PDF of sunroof disassembly/reassembly if you are interested, but l will need your email-mail to send it via Dropbox. Too large a file to send otherwise.
“As new technologies become indistinguishable from magic, and I can no longer tinker, the magic goes away for me.” |
Well I only have 1. Now I guess I need to figure out how to get another one! |
doing a full sunroof delete. after cutting out the cassette and pulling all the parts I found one of those. no idea what it was for but then without the sunroof not needed any more....
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold
You mean one is missing? That could only have happened during some prior disassembly. There should be one at the rear of each track. I think if it is not in place there could be a significant water leak.
Good luck finding that. Maybe you could find someone to 3D print it. Shouldn’t be hard, and it’s not a structural part. Once it has performed its functions (locating the rear of the track and plugging the hole) the actual securing of the track in position comes when you screw it down.
To follow up I realized the one I had was bent and the other was completely missing. My buddy made me two on his lathe and they worked perfect. Here is the old bent one and one of the new ones. Glad I have friends that are way more talented than me. I could have never made that by myself.
I'm good with tools.
Friends are nice !!!
72 911 Coupe "OILDOOR" 24 INEOS Grenadier (daily) 13 991.1 Coupe 2S 3.8L (currently undergoing mods) 02 996 4S |
