1984 Door Lock Cylinder mystery
Hey, hope someone has some knowledge on door lock cylinders. I am working on a 84 that when i bought it was missing the driver door lock cylinder. In the picture is the remains of what i have when i take it apart, i have ordered from two different sites (our host also but was cancelled because discontinued) but non of the cylinders that i bought fit, they are too short and seem to be for a different handle. Is this handle not for a 84? and where would i get a lock with key that fits in my handle?
Thanks in advance.
Old 01-16-2020, 12:37 PM
proporsche's Avatar
i believe the handle on your picture is for door with central locking system.That little plastic tube is for triggering the little niple on door locking sensor.
Ivan
this sensor goes on the side of you handle
1985 911 with original 502 191 miles...808 198 km
Old 01-16-2020, 02:35 PM
proporsche's Avatar
here, i just took a pic of my sensor so you can see the other side
Old 01-16-2020, 02:47 PM
Analog Air Cooled
Hotshot's Avatar
Not sure if this helps, as I’m dealing with my own strange lock issue, but this is a stock 86 lock. As far as I can tell 84-86 are the same.
On the top pic, you have see the “tube” that accepts the central lock trigger. It just moves it L-R to actuate the switch.
I cleaned mine out and made sure the electric switch was working as it should. I found that the bolts that fasten the door to the lock screw into the Handel, and if not set all the way in/deep, the spring on the handle pull will bind or interfere with the turn key mechanism.
86 Targa
91 964
13 6 SPD Cayenne
Old 01-17-2020, 04:06 AM
proporsche's Avatar
back to the origin..as i have mentioned ..Do you have central locking in your 1984 911 ..i suppose it did not come yet in 1984..then we can talk ..You need the longer version of tumbler..for this door handle...........
Ivan
Old 01-17-2020, 04:49 AM
proporsche's Avatar
if you have received short tumblers..they are for this kind of door handles
Ivan
Old 01-17-2020, 05:25 AM
Hey all, thanks for the quick response. OK now it all makes sense, or a little more. You are right i think in 1984 there was not central locking. On mine someone installed the system afterwards, there are the cylinders in the door screws in not by factory i removed all that. When they did that i guess they had to replace the driver door handle with one for central locking. but oddly there was no sensor hooked up to the handle. In the passenger side i have one like Ivan shows in the picture, with not central locking as the 1984 should have.
But now are the locking cylinders different from the non central handles to the central locking handles? The one i got fits on my passenger side but is too short for the driver side. I guess i have to either buy a new non central handle or a cylinder that fits, which i would prefer.
Old 01-17-2020, 05:58 AM
cycling has-been
bkreigsr's Avatar
Any dealer. or locksmith familiar with German cars, will be able to recreate your key.
Bring them the finished assembly before you install it, and they can read the key-code from the stamped numbers on the 10 flags in the cylinder.
Bill K
Old 01-17-2020, 11:54 AM
Hey Bill, yes i know the problem is i dont have the lock cylinder along with the key, i did not just loose they key but need the cylinder that goes into the handle.
Old 01-17-2020, 11:57 AM
proporsche's Avatar
i will look if i have one tomorrow..maybe some oldtimers here have something in their stash;-)?
Ivan
Old 01-17-2020, 12:09 PM
Thank you Ivan, that would be awesome if you could find one, i would really appreciate looking.
Old 01-20-2020, 05:54 AM
proporsche's Avatar
I did look but unfortunately i only have the short tumblers...
Ivan
Old 01-21-2020, 07:14 AM
Hey Ivan, you have a handle with a non central lock and short tumbler you would sell to me?
Old 01-21-2020, 10:37 AM
proporsche's Avatar
i only have a black pair with a key matching ....as the pic on top..it will be hard to break a set from the door handle...i`m sure somebody in your side of the pond will have one ....
Ivan
Old 01-21-2020, 10:48 AM
