-   -   CV joint/Boot kit for 911 Turbo/ 930 (http://forums.pelicanparts.com/porsche-911-technical-forum/1050732-cv-joint-boot-kit-911-turbo-930-a.html)
oldmerakguy72 01-23-2020 03:20 PM
Greetings all,
I have a 1978 Maserati Merak that needs CV boots and joints. Information on the Maserati is elusive, but the 308 Ferrari uses early 911 turbo parts, which look identical to the Maserati pieces.
I have a part number on the Lobro boot, 215315750003 but can come up with exactly zero matches anywhere. The halfshafts have 28 spline count, same as Ferrari (and apparently the '75 to '83 Porsche) and all parts for the Porsche look like the Maserati shafts (the Maserati has metal overs on each end of the CV joint)'
My question is, can anyone tell me the diameter of the Porsche shaft and the diameter of the splined end? Apparently it's a fact that Porsche and Ferrari use the same CV joint, just need to confirm now the relative sizes of the shaft and CV joint itself
Many thanks,
Carey
DaytonaCoupe66 01-24-2020 05:08 AM
Some great info in this thread...
http://forums.pelicanparts.com/porsche-911-technical-forum/596183-cv-axle-cross-reference.html
Best of luck.
oldmerakguy72 01-24-2020 03:31 PM
thanks so much for the info----I'll start slogging through it
carey
