-   -   connector for knock sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1051004-connector-knock-sensor.html)
T77911S 01-27-2020 06:37 AM
where would I get a connector for this knock sensor
http://forums.pelicanparts.com/uploa...1580135853.jpg
Dpmulvan 01-27-2020 08:24 AM
Amazon, just type in knock sensor pigtail
patkeefe 01-27-2020 09:52 AM
www.eagleday.com
There are other places online, but I forget them off the top of my head. I think that is a sort of AMP connector.
dap930 01-27-2020 09:53 AM
It is the same connector as used for EV-1 fuel injectors.
spuggy 01-27-2020 02:09 PM
It's an Tyco/AMP (Amphenol) Junior Timer connector.
rsscotty 01-27-2020 05:46 PM
This does not take a Tyco/Amp connector.
It uses a Bosch Compact 1
You can get the kit from Finjector, part number (1 928 403 137 ) The kit labeled SET-1 will work with 17-20 ga. wire
Not easy to find parts in kit form.
spuggy 01-28-2020 02:42 AM
Huh, never noticed that before...
Bosch knock sensors are available with 2 types of connectors (and also the "modern" connector can be had either terminating on the sensor body, or with an attached lead - KS-4-S vs KS-4-K1 respectively).
Bosch says knock sensor connectors are either:
2-Pin RB-Kp.1 (F 02U B00 966-01)
Or
2-Pin Jetronic (D 261 205 288-01)
The Jetronic is the same connector as a Bosch NTC thermo-sensor (same family as the 3 pin variant often used for the mag crank/ref sensors), often called a JT connector. Same as many connectors on a CIS loom - eg WUR, AAR. That's the only type I'd seen.
The JT can be crimped satisfactorily with a $15 ratchet crimper with suitable dies for open-barrel terminals and the gauge of wire used. Dunno about the other one.
T77911S 01-28-2020 03:53 AM
this one takes the EV1?
does it matter which one I use.
would like to use one that I can easily find a connector for but also works well.
http://forums.pelicanparts.com/uploa...1580212325.jpg
Quicksilver 01-28-2020 11:05 AM
A Junior Timer connector is much more rectangular than that.
(It is surprising how many places the Junior Timer connectors are used. First place I saw them was the crank sensors on the Carrera but now I see them all over. They even use them on my cheap 90's Nissan pickup!)
winders 01-28-2020 11:48 AM
https://www.bmotorsports.com/shop/product_info.php/products_id/942
T77911S 01-29-2020 03:58 AM
does it really matter which sensor I get.
been trying to get info on them but not really any out there.
I assume the 2 wire ones are better than single wire for noise
spuggy 01-30-2020 05:11 AM
Bosch publish several datasheets, including drawings, fitting specifications and vibration/thermal/corrosion/lifetime specs.
Google "bosch Y.261.K23.205" for the Jetronic connector and "bosch KS4-P datasheet" for the other one.
Apart from the connector, they're the same sensor.
They're all 2 wire, it's a piezo microphone. Doesn't matter which wire goes where, but you need both. The only difference is the connector; which is better for you probably depends on which crimping options you already have.
kevingross 02-02-2020 06:17 PM
https://www.bosch-connectors.com/
T77911S 02-03-2020 03:51 AM
I ordered 2 of these.
came with connectors so no worries.
https://www.bmotorsports.com/shop/product_info.php/cPath/129_589/products_id/4514
also ordered this air temp sensor.
I ordered a M18 to M14 adapter so I can mount it in the IC right above the throttle body.
hope the engine shroud does not get in the way.
https://www.bmotorsports.com/shop/product_info.php/cPath/129_142/products_id/4174
