It is determined by tire pressure and sidewall stiffness contact patch shape is determined by the profile a 225/50 x15, 225/50 x16 225/50 x17 and 225/50 x18 will all have the same contact patch shape and area if the sidewalls and tire pressures are the same What will be different between all of these tires is the height 23.9", 24.9", 25.9", 26.9" The taller heights mean the sidewalls are taller and thus have more play in them during cornering, this results in decreased grip as you go from 15 thu 18 To counter act this trend as the wheel increases in diameter the profile needs to be reduced so a 225/50x15 will be roughly comparable(grip & height) to a 225/45 x16 will be roughly comparable to a 225/40 x17 will be roughly comparable to a 225/35 x18 all else being equal |
Maybe they are in the table you posted but I'm unable to find them... |
205/50 x15 runs from ~15-19 lb-ft, depending on weight 205/45 x16 runs from ~17-20 lb-ft, again depending on weight |
| All times are GMT -8. The time now is 02:48 AM. |
