Bleeding turbo brakes
With the turbo brake system the calipers each have two bleed screws. I can’t find any instructions on which bleed screw should be bled first. Or does it even matter? Thanks for your guidance.
Old 02-06-2020, 05:58 PM
Mahler9th's Avatar
It does not matter. In my experience, sometimes the bleed screws are a little stuck, so I use a deep socket to crack them open, then closed. And the when bleeding I almost always use a box end, offset spanner.
I usually use my Mityvac, sometimes I use my Motive tool. The Motive works well and I know the owners of that company. They are car guys.
Mike
PCA Golden Gate Region
Porsche Racing Club #4
BMWCCA
NASA
Old 02-06-2020, 06:13 PM
Mighty Meatlocker Turbo
Rawknees'Turbo's Avatar
The best/quickest way to purge those calipers is to open both bleeders together.
Old 02-06-2020, 10:38 PM
Flojo's Avatar
bleeding starts always from the bleeder nozzle the furthest from the reservoir away.
so for the two-bleeder version calipers (930, 964, etc), you bleed from the outside to the inside.
for a proper bleeding of these types of calipers you'll need double the liquid as for regulars.
regular calipers (S/SC/Carrera):
right/rear
left/rear
right/front
left/front
doubles:
right/rear/outer
right/rear/inner
left/rear/outer
left/rear/inner
right/front/outer
rights/front/inner
left/front/outer
left/front/inner
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-07-2020, 01:16 AM
That is a bunch of unnecessary work/steps for absolutely zero benefit.
Old 02-07-2020, 10:51 AM
REALLY?? sequence does not matter? please confirm...
Old 02-07-2020, 01:59 PM
Sequence on calipers with multiple bleed screws does not matter, and in fact, it is much more efficient to open both/all of them at the same time.
And overall caliper sequence also has no measurable bearing with regard to purging air from the system (it is a long standing myth that it does). I have put this to the test many times, on many different machines, and it absolutely does not matter which caliper you begin with.
Old 02-07-2020, 03:21 PM
