Eng-o-neer
Tremelune's Avatar
Unhappy Collapsing sheetmetal screw anchor for RS door card handles??
My car has RS door cards. The handles attach to the doors by drilling a 10mm hole and installing a collapsing anchor into which an M5 screw threads in. One of my anchors fell out, and I'm trying to replace it.
I can't seem to find one of these anywhere...The hole is too big to fit a rivnut while still using a screw that is close to M5 in size...Does anyone know what these things are even called? Searching numerous variations of "sheetmetal collapsing threaded insert" turn up no easily-purchasable product in the US...
Old 01-23-2020, 07:47 PM
The one in your pic is called a jack nut. Dunno who that particular manufacturer is though. A plusnut is similar.
Old 01-23-2020, 07:57 PM
Eng-o-neer
Tremelune's Avatar
YES! Thank you! This has been killing me!
Old 01-23-2020, 08:00 PM
dreichman's Avatar
Something similar happened to mine also. They did not come out like yours has. Mine started to spin so you could not tighten the screw. I ended up tack welding them in. Haven’t worried about them since.
Old 01-23-2020, 11:02 PM
I replaced my RS door cards with new ones and refused to use those things. I bought a rivnut puller and some rivnuts. Very solid.
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 01-24-2020, 09:47 AM
Eng-o-neer
Tremelune's Avatar
Yeah, they are not a great fastener...The one that's still there is spinning. It's maddening. Not much I can do with a 10mm hole besides put them back in and tack 'em...
Old 01-24-2020, 09:49 AM
Fleming's Avatar
Try here for 5mm Rivnuts priced for each, (not 100 min.)
https://www.treefortbikes.com/Marson-5mm-Rivet-Nut-Sold-Each?utm_source=google&utm_medium=cpc&adpos=1o1&scid=scplp333222384588&sc_intid=333222384588&gclid=EAIaIQobChMItamn_YSd5wIVEfDACh2U9QqNEAYYASAB EgKtUvD_BwE
give them a try and see if they work for you.
Old 01-24-2020, 12:13 PM
Eng-o-neer
Tremelune's Avatar
Unfortunately, there is already a 10mm hole that I need to use, and I lack the skill to weld it closed...
Old 01-24-2020, 12:17 PM
Under the radar
Trackrash's Avatar
I have welded a nut to a small piece of sheet metal with a hole in it. That can then be riveted into the door panel.
Gordon
'71 911 Coupe 3,0L outlawed
Old 01-24-2020, 01:09 PM
MBAtarga's Avatar
This is a low torque application - how about filling or installing with JB weld?
Mark
'83 SC Targa - since 5/5/2001
Old 01-24-2020, 01:55 PM
Eng-o-neer
Tremelune's Avatar
I bought some janky jack nuts on eBay as part of my first attempt...They just twisted in place—they didn't spin, the collapsable structure simply collapsed into a twist instead of pulling flush.
I wound up using an M6 threaded insert (Rivnut) as its outer diameter was .86mm...I thought it would be too small, but it's already more solid in place than the "good" fastener still installed...
Old 01-29-2020, 08:47 AM
Eng-o-neer
Tremelune's Avatar
You underestimate a passenger's propensity to slam a door...
Old 01-29-2020, 08:48 AM
