-   -   Changed O2 Sensor (http://forums.pelicanparts.com/porsche-911-technical-forum/1051463-changed-o2-sensor.html)
Funracer 02-01-2020 07:31 PM
Changed O2 Sensor
Changed the O2 sensor. Want to reset the 30K mile counter for the OXS light to align it with the new sensor.
Found the white button but it does not push or move, maybe because it is not popped out?
Since my OXS light was not on to start with, can the O2 counter be reset to zero or can it only be reset after it trips every 30K miles?
Nick Triesch 02-02-2020 07:26 AM
Air cooled car??
stevie 77 930 02-02-2020 08:06 AM
it can be reset as often as you would like.......
pull your clock or speedo out and you will find the counter below it all..... scroll down in this thread and you will see it, its not the white button
http://forums.pelicanparts.com/porsche-911-technical-forum/658657-how-can-sc-run-w-o-oxs-system.html
bkreigsr 02-02-2020 09:25 AM
You guys are the bomb.
Bill K
Funracer 02-03-2020 10:39 AM
Thanks guys. I had seen that photo long ago and could not find it again. Also thought I had added my car to My Garage but it is in there now.
Regards
