Help identifying wire 89 Carrera
Had to remove the fuel pipe from the tank to the fender and this wire was just hanging around, Yellow/white and brown. Can't find any unoccupied female electrical connection. The pict does not have the metal fuel pipe to the fender installed. Any ideas? Had to replace the fuel tank filler seal. A PIA until I figured the trick to installing the seal through the fender into the trunk. Thanks in advance. Steve
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 02-07-2020, 06:01 AM
It's for the intensive headlamp washer system, which was an option and presumably your car doesn't have. The connector is not used.
Old 02-07-2020, 06:21 AM
Thank you. That was my guess.
1970 911T SOLD
1989 3.2 Carrera
2013 991 Carrera S
Old 02-07-2020, 08:03 AM
