CDI changed to CLASSIC RETROFIT CDI+
Just finished installing my newly purchased, from PELICAN PARTS, Classic Retrofit CDI+.
My original CDI was working fine but after trying to find a correct rev limiting rotor for my 1979 911 SC (ROW) that I Autocross all summer long ( and I really need the rev limit protection!) decided to go this upgrade route. The benefits of the CDI+ should help to bring my ignition into the 21st century and reduce my worries of the 40 year old unit failing or losing performance. The installation was very easy and the instructions are detailed and easy to follow. I just did the plug and play option and did not do any software mapping. I did adjust and calibrate my tach and set the hard and soft rev limit to my desired numbers. The car started right up and runs great. I will have the AFR adjusted to reap some additional power as suggested in the instructions. Did additional replacing of a new “black CDI coil”, new Beru shielded wires, and new spark plugs as was suggested by CLASSIC RETROFIT. Anyone hesitant about the cost should know this is a high quality product with 21st century engineering with substantial benefits as compared to buying a original CDI box. |
Sweet! I ordered the last one Pelican had in stock. Should be here tomorrow.
I’m also searching for the elusive black coil although Jonny responded to my PM saying the silver Bosch has the same specs just not the reliability of the original. I plan to switch from CIS to carbs in the not too distant future so the cost of the CDI+ vs having my existing distributor recurved wasn’t all that much. Having the advantage of the multi spark in the meantime is a plus. |
I had bad experience with Bosch silver coils. I have barn find 76S with 3.0 liter PO haphazardly installed, had things together with bailing wire. Replaced silver Bosch coils three times before discovering on this forum that they’re no good. I only put 200-400 miles on the coil each time and left me stranded. I thought it was engine related and discovered the silver coils can’t withstand the engine heat. Buy the MSD coils and remove the sticker. Don’t buy Bosch silver coils unless you like riding in tow trucks. |
Finally got a chance to install the CDI+ after checking the timing and making a small adjustment I swapped my rebuilt and by all accounts perfectly functional Bosch unit for the CDI+. Checked timing again, it was bang on so I took it for a quick spin in the neighborhood.
I don’t know if it’s a placebo effect or what but it seems WAY smoother at low RPM and low speeds. It was always a little jerky in 1st gear parking lot situations and I just chalked it up to the nature i of the car, but it’s completely gone now. I’m excited to see how it fairs on a longer test drive and to delve into some of the more advanced features. |
yes, that was also my experience and many others with me. Much smoother low rpm running.
^ Combustion analyser says better burn, dyno says more power. Around 800 cars running CDI+ now. That’s enough of a sample size to quash any notion of placebo. To think I had to fight it out with some on here a while back - so over that now!
We’re currently testing on historic F1 Cosworth DFV V8 at 10000 RPM. |
^. Yes we used to sell a replica coil but we had failure issues and also with the orange plastic being too brittle. This led to cracking around the terminals and the ‘nose’ of the coil.
It is a shame because the specification and performance of that coil matched the Bosch unit pretty well. Essentially, a large proportion of canister style coils are made in China to a price. That includes all the common US brands. We are now working to produce a high quality canister coil in the U.K. having found a partner with the proper old school winding equipment. Everything including the wire will be quality focussed. It will take us a few months to get going. |
(EDIT - PS - Thanks for the reply! - And for continuing your efforts!!) |
I feel my foot approaching the slippery slope.
I've been looking at 123 Ignition and it seems like the 123 ignition + the Classic Retrofit CDI might be a good marriage. Do you think there's benefit to be had from this combination to (self) justify the $1,500 investment? |
It depends on the condition of the old distributor. One one of my other vintage cars experienced low RPM running issues that were never solved until switching to the 1-2-3 Ignition distributor. Even after tests said it was "within spec" the 50+ year old distributor was just not working as it should. Things wear out eventually.
In a 911 with a good distributor Classic Retrofit CDI may be all you need. That said, I can see certain scenarios on older 911's where the 1-2-3 Ignition distributor + Classic Retrofit CDI might be a very good combination. |
I installed a 123ignition. At first the performance was great. In then started to deteriorate. I notice the advance exceeded to config. I took it apart and saw evidence of arcing on the leading edge of the rotor and cap. I contacted 123 they were no help at all. The US distributer defaulted to the overly simple manual and wouldn’t contact 123 in Holland on my behalf. I restored my Bosch distributor and reinstalled it. The car runs again.
Interesting, because it's been my experience that with a good CDI you can generally increase power by retarding the timing a few degrees over stock. And it's because the initial flame kernel is larger so combustion proceeds at a faster rate initially. That's with standard to lean mixtures. Overly rich and one would likely need to advance the timing over stock regardless of the ignition system, but less with a decent CDI. Fred
You are aware of performance "tuning", right? Well, for a stock engine with the AFRs set properly, advancing the timing is all that's done. Just some very basic knowledge, a PC, and a tuning app is all that's necessary. A HS auto shop student is more than capable of "tuning". Some have indicated that for every degree of timing increase, about four ft-lbs of torque results. |
| All times are GMT -8. The time now is 09:34 AM. |
