NO power to fuel pump 79 turbo cis
I tried to use search bar but could not find the way to by pass the relay. here is whats going on car has no power to the fuel pumps when I turn the key.
motor is a 79 turbo sitting for 20 years indoor my questions are does there need to be gas in the tank like a fuel level cut off? is there a way to bypass the relay to see if the pumps work ? any help is appreciated I'm not afraid to read just looking for help to links or someone who could maybe help me out.
There's an over boost fuel pump cut-off relay on the rear electric panel that may be the problem. Also 2 fuel pump relays on the front panel and a fuse.
I checked the relay up front but my car has only one ? also I will check the over boost fuel pump cut off thank you
930 fuel pumps test.........
Turn the ignition switch @ ON position (not START) and disconnect the AFS (air flow sensor) switch. The two (2) FP’s should run.
Tony |
