WIP, Dual Master Cylinder, Part I
Here is my attempt at a dual MC system.
A 911 buddy has modified the stock pedal cluster to accept the 2 MC's. http://forums.pelicanparts.com/uploads/MC and Pedal.jpg Next step will be to remove the orginal pedal cluster and install the modified one. This will require fitting the PC into the car. The PC will first be bolted to the stock rear 8mm studs. Then the 2 new 8mm front holes and 2 MC holes will be marked on the front firewall. The four holes will be drilled out as marked. More updates as things progress. |
| All times are GMT -8. The time now is 11:40 PM. |
