-   -   door window frame compatibility (http://forums.pelicanparts.com/porsche-911-technical-forum/1052117-door-window-frame-compatibility.html)
Yan2947 02-09-2020 06:10 AM
Does anyone know if the door window frames from a 1986 911 interchange with a 993 or 996 coupe? They look the same. Here is a photo of a 993 frame. And if they fit then I would assume that the window glass is the same also?
My doors are fine but the frames and glass were damaged.
http://forums.pelicanparts.com/uploa...1581257413.jpg
