Hill Assist
Ok guys, don't dump on me for this post
My DD is a manual transmission, been driving manual transmission for over 40 years. On my weekend drive I have to drive thru some traffic on some hilly roads before I get to the open road. Always feel uncomfortable with hill climb of my 84 Carrera, mainly me thinks of the arrangement of the pedals on these cars compared to a modern cars. I am thinking ![]() Any ideas (don't need a lesson on how to drive a stick) Thanks
South Africa, 1984 Porsche 911 3.2 RHD |
Hold the hand brake on, and drive off normally as if you are on the flat. Once the car is well and truly moving forward release the handbrake.
The tip comes from Bill who lives in the world's steepest city. Moy blay (spelling?), Bill. Last edited by Bill Douglas; 02-03-2020 at 10:54 PM.. |
Uncertifiable!!!
You need an extension to your gas pedal so you can modulate the rpm while having the heal on the brake pedal.
Cheers,
🇨🇦 The True North Strong and Free 🇨🇦 Living well is life's best revenge- George Herbert (1593-1633) 2006 C2S, 2024 WRX GT, 911 hot rods on Pelican…. Evolution of a Carrera RST, and Sweet Transplant |
I believe people have added the earlier hand throttle to later cars if that is what you are truly looking to do. I’ve used the handbrake suggestion successfully backing out of steep driveways.
Ass-engine Nazi slot car -- PJ O'Rourke |
Exactly so.... that's why the handbrake is within easy reach. Use that all the time in hilly NW Pennsylvania.
'88 Carrera Guards Red '70 VW Beetle Yukon Yellow ![]() |
1988 Carrera
Being from the flat lands I never gave this a thought. Nest time I drive thru the mts I'll keep this in mind.
88' Carrera 79' SC gone (lost to Katrina) 75' Targa gone 72'914 gone 72' 914 gone too |
Yeah... never saw the mechanism, but someone said some of the VW Beetles had a hold brake mechanism for hills that would allow you to remove your foot from the brake pedal on a hill to keep you from drifting backwards. Not really necessary with the handbrake performing the same function and being in easy reach IMO. Just have to coordinate the release of the handbrake with the actuation of the clutch.
Practice the coordination on a flat piece of road...once you have it down, inclined surfaces do not present any problem. Dennis |
Or, go like hell from a standstill...
I would rather be driving
Or adjust the brake pedal down slightly and the gas pedal up. Should not need an extension if one setup pedals to their liking.
Jamie - I can explain it to you. But I can not understand it for you. 71 911T SWT - Sun and Fun Mobile 72 911T project car. "Minne" - A tangy version of tangerine #projectminne classicautowerks.com - EFI conversion parts and suspension setups. IG Classicautowerks |
Easiest way is to use the handbrake.
78 911 st backdate 87 944 00 996 |
abides.
Haven't really had a problem with this in my Carrera... the 3.2 with motronic is torquey enough at low rpms in 1st gear that i never really needed to rev the engine excessively, unless it was a very steep hill.
Graham 1984 Carrera Targa |
Troll Hunter
The only trouble I've had in 50 years of driving dozens of clutch cars is when the clutches are pedal high, adjusted incorrectly or worn. A low clutch never gives me problems.
1978 SC Coupe, Gris Argent Metallic Silver 1988 FJ62 Blue/Gray 2020 M2 CS |
My clutch is new and relatively high. Release point @ 3/4 way I would say
Like others said, I’d adjust the pedals.
This reminds me of when I was a valet at a nice hotel in Austin in the 80’s. I loved when I got to park 911’s but I also dreaded the clutch since it was by far the most difficult of any manual cars I parked. I used the handbrake ![]()
2014 Cayman S (track rat w/GT4 suspension) 1979 930 (475 rwhp at 0.95 bar) |
914Rubber has a choke kit that would work for you. It designed to keep the revs up when your warming up the car.
RETIRED
EBrake is how I learned on my 56 bug. Standard rule #1 on driving a stick from a full stop on a hill.
1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel |
and while the hand brake makes great sense, I tend to just just give it gas and go ... Jason
'79 911SC Targa |
Still here
Arrangement of pedals is just like my DD manual.
What modern cars are you talking about ? |
The Porsche has its pedals off the floor board my DD has suspended pedals like every other modern car
