Pedal box shaft has sheared
Pushed the clutch and bang. 68 911 . first of all is this common ??
Its been repaired by the looks of it. My next question is how do I clock this for the repair. I can't get in that hole and try to judge where I think it should be. Can some one post a pic or state where the arm should be in relation to the pedal or the split pin
Thanks Lyndon
Old 02-10-2020, 01:14 AM
proporsche's Avatar
it is called pedal cluster cross-shaft just get a new piece...
here is your part number
901 423 320 01
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-10-2020, 02:44 AM
Lyndon
Old 02-10-2020, 03:03 AM
It is a cheap simple part. It is a real pain to replace. Remove the pedal cluster from the floorboard. That means disconnect the throttle, clutch cable and the bolts to get the cluster out.
Disassembly is not easy. "While you are in the there" your wise move is to rebuild the entire pedal assembly. Then reinstall in place. If your clutch cable is old, replace it as well because you have half the job done already.
Good luck.
Old 02-10-2020, 10:42 AM
proporsche's Avatar
Glen.. it looks like it`s a fresh rebuild with copper parts on it already..
Ivan
Old 02-10-2020, 11:07 AM
