Front Suspension bolts questions!
Hey guys, I've got my '71 front suspension apart, getting new control arms, suspension rack rebuilt, powercoated the struts, an aluminum crossmember upgrade waiting to go on it, replacing tunnel and front brake lines, and changing out the shift rod bushing.
1. I'd like to use new bolts for the crossmember. Is there anything special about the Porsche crossmember bolts or can I just go and get M12 x 1.5 x 85 mm long, strength class 8.8 bolts at Fastenal?
2. I boogered up one of the torsion rod adjustment bolts. Cant I just go get a bolt that fits? Sure it'll have a normal size bolt head, but functionally shouldnt it be just fine?
thanks!
Old 02-13-2020, 04:57 PM
Bland
RWebb's Avatar
I did the same swap and used the Porsche items to be safe.
Old 02-13-2020, 05:46 PM
Flojo's Avatar
8.8. or 10.0 are fine if you get same-same replacements at the hardware store.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Parts: https://www.instagram.com/spadescustomz_/
EGO: https://www.instagram.com/911garage_germany/
Old 02-14-2020, 03:56 AM
I agree, but most hardware stores have silver zinc plated botls which should not be used.
Also, for the torsion bar adjuster screw, the replacement is inexpensive and readily available, so why not just purchase that?
Old 02-14-2020, 04:38 AM
Flojo's Avatar
indeed, nothing wrong with original
Old 02-14-2020, 04:58 AM
gtc gtc is offline
abides.
gtc's Avatar
What is wrong with silver zinc bolts?
Even the hardware you get at a dealer might be silver these days.
Graham
1984 Carrera Targa
Old 02-14-2020, 10:01 AM
At $42.50 for one bolt, it pretty expensive and then you add the shipping cost... so $50 for one bolt. It's a little rich for my blood!
https://www.pelicanparts.com/More_Info/91134111502OEM.htm?pn=911-341-115-02-OEM&bt=Y&fs=0&SVSVSI=5867
Also, why not the zinc plated bolts? I do think we should put Never Seize on the treads too.
Old 02-14-2020, 10:28 AM
Under the radar
Trackrash's Avatar
Location: Sebastopol, the land of wine and redwoods in The Republic of California.
I too, would like to know what is wrong with silver zinc bolts.
FWIW, you can get the yellow chormate conversion solution and then dip the silver zinc in and turn it yellow.
The last hardware I bought, the cam oil line, was silver zinc from our host, so I dipped it to get the yellow color.
Also, the original bolts on my car are 8.8s. I think it is a good idea to use anti-seize on these bolts.
Gordon
'71 911 Coupe 3,0L outlawed
Old 02-14-2020, 11:18 AM
Standard zinc is the least corrosive resistant plating found on bolts. Select a conversion coating, stainless or cad. That's what car manufacturers do.
I'm not sure what coating Fastenall zinc is, but because they specify for automotive, I would guess it's a conversion coating. It's worth asking them.
https://galvanizeit.org/corrosion/corrosion-protection/zinc-coatings/zinc-plating
Old 02-15-2020, 07:51 AM
Under the radar
Trackrash's Avatar
I don't see in your link about comparisons of zinc to other coatings. Only that the quality maters. Did I miss something?
Stainless coated bolts? Where can I get those?
Cad is hard to find, except for aircraft stuff? What is a source for gold cad plaited bolts?
Conversion coating? Please explain what that is. Do you mean black oxide, or chromate or?
Thanks,
Gordon
Old 02-15-2020, 06:42 PM
ILXLR8's Avatar
Here is a good source for metric hardware. https://www.belmetric.com/
Old 02-15-2020, 07:14 PM
