I just got my replacement bushings from Pelican, and they are the hard (Sports) style, not the soft rubber ones, for the front a-arms in my '69 T.
I had planned to use a thin layer of grease on the inside only as I installed them, but then read a recent post warning against lubing Neatrix bushings... What is the right way to do this?
-Rickeolis- 1986 Corvette |
Formerly bb80sc
Mmmmmm, fun job
![]() Just use a non-petrolium based lube. You'll probably have to sand down the outside of the bushings to get them to fit, pretty snug.
Cheers -Brad 2015 Cayman GTS 2015 4Runner Limited |
Neatrix are rubber and break down from petrol based grease. Your bushes are poly.
Your only hope at minimizing squeaking is to lube them with grease. Poly doesn't break down from petroleum grease.
Chuck Moreland - elephantracing.com - vonnen.com |
Formerly bb80sc
Thanks for keeping me honest Chuck
I ued some kind of gorilla snot bushing grease from the Performance catalog.. a real PIA to get your hands cleaned from that stuff.......Ron
Ronin LB '77 911s 2.7 PMO E 8.5 SSI Monty MSD JPI w x6 |
Ron, that was probably a silicone grease designed for burette stopcocks (chemistry class).
I got some of that lab silicone stuff also.. but this gorilla snot is way different.. I'll put a dab in the mail if you want......Ron
Noooo I definitely don't want. However, if you have an extra brunette item I'd like to review that....
Senior Member
Well, there's that old thread discussing the zerk fitting install. That's what I did.
Man of Carbon Fiber (stronger than steel) Mocha 1978 911SC. "Coco" |
Thanks guys, so a little light grease it is...
