Warm start issue - Still a problem after accumulator change
Hi,
I have a 1979 911 SC Coupe Manual with a warm start issue. Car starts first go when cold. Can also be restarted easily when warm if restarted within 5min . Any longer and it takes some cranking to restart it. I've changed the fuel filter and accumulator as the symptoms matched what others on this forum had described. I still have the warm start issue. Other thing I've noticed is that once fully warm, the engine idles up and down. If I give the throttle a blip, it settles back to a normal idle until I come to a stop again. Otherwise the engine runs beautifully when driving. Any suggestions would be greatly appreciated. Cheers, |
Subscribed
I have the same situation. I also replaced the fuel pump. Thanks. |
Residual fuel pressure...........
Your problem is residual fuel pressure loss due to internal fuel leak. The three (3) most common culprits in a CIS are: 1). Defective fuel accumulator. 2). Defective fuel pump check valve. 3). Defective primary pressure regulator. You need to test and verify that all these components are all good and working. You will need a pressure gauge to confirm their conditions. Keep us posted. Tony |
Nope......
While fuel accumulator is the most common culprit for residual fuel loss, the two (2) others are as likely the culprit/s. Stop guessing and perform a systematic troubleshooting. Do not replace CIS parts unless tested and verified defective as demonstrated by OP. Tony |
Hook up the gauges, get the engine hot then let it sit and watch the system pressure. When and if it starts dropping, be ready to block off parts of the system. I realize easier said than done, but that is how you do it. Devise a system to facilitate doing that. Tedious and time consuming. Bob
| All times are GMT -8. The time now is 03:30 PM. |
