-   -   K&N part # help? (http://forums.pelicanparts.com/porsche-911-technical-forum/105320-k-n-part-help.html)
k9handler 04-06-2003 09:07 AM
K&N part # help?
I need to get a cone filter for my 3.6 (993)...and I have the specs and what I believe is a cone that will fit. Will somone with this style cone chime in here and tell me if this will work? Or the part # for the cone filter you are using. Thanks.
Flange: 89 mm (3.5")
Length: 178 mm (7") or smaller will work.
The only cone in this spec range I found was part # RE-0950
Thanks.
