l_turn9's Avatar
Adhesive for Door Seal
Hi All,
I installed door seals a couple of years ago but the bottom rear corner (a curve really) won't stay glued down.
What the best adhesive to use to keep door seals firmly in their channel?
Thx
LarryT
74 911
Youroil.Net
Old 03-26-2020, 08:09 AM
proporsche's Avatar
3M adhesive Black Weatherstrip 08008
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-26-2020, 08:31 AM
walt's Avatar
I used the Permatex equivalent to 3M which is 81731 which is amber colored. I just used a bit in the lower 2 corners.
Walt
82SC 3.0
81SC 3.6
Old 03-26-2020, 09:54 AM
It helps to really clean the channel out, getting the old adhesive and stray bits of the old seal out so the new one nestles down in there. Then it doesn’t take much adhesive, best to keep it to a minimum.
Old 03-26-2020, 10:42 AM
Bill Douglas's Avatar
Make sure it's not too stretched going around the corner, so it doesn't want to pull out of the groove. Do the stretching to fit along the straight parts. Good luck, it's annoying it coming out all the time. Mine did that too.
Old 03-26-2020, 01:44 PM
Grappler
Rodsrsr's Avatar
Make sure its a nice hot day too. I used the Permatex on a hot day and just kept the door shut on the seal all day.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 03-26-2020, 05:53 PM
honestly, when i finished putting together my green car, i just threw the seals in sans adhesive so i could get the car on the road and shake it down.
year and a half later, i still haven't pulled the seals back out to put down adhesive. seal has popped out a couple of times in one corner, but mostly stays put.
i'll get to it one of these days.
maybe....
1971 914-6 GT 3.6
1974 911
1976 911S leaf green backdate 3.2
Old 03-26-2020, 06:23 PM
I use tire glue like road bike riders use for tubular tires, looks and smells like the original and worked great. It's also what I had on hand at the time, and its cheap.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-27-2020, 04:35 AM
l_turn9's Avatar
Can you be a little more specific? Not really sure what "Tire Glue" is. Where on the Tire/Tube is it applied?
I found this "Kex Cold Vulcanizing Rubber Tire and Tube Patch Plug Repair Cement Glue " and this "Bob Smith Ind IC-2000 Tire Glue -1 ounce".
Am I getting close?
Thx
Larry
74 911
Youroil.net
Old 03-27-2020, 06:03 AM
Parabond M250..from heavy duty carpet install to rubber weatherstrip. Typically available at flooring supply places.
Old 03-27-2020, 06:08 AM
Wildman Emeritus
Tubular (sew up) tire glue is available at most bike shops for us old school guys. Several mfrs. produce it. Tubulars are a combo tire/tube set up where the glue is applied to a strip on the inner circumference of the tire or to the rim and then the tire is stretched around the rim. I have done dozens over the years and it is still a messy procedure.
I call it the glue from hell and dread changing a tire.
Personally, I would use 3M or Permatex as it is readily available at auto parts stores.
Mike Andrew
1980 SCWDP
2024 Suby Forester
2018 BMW X1- Wife's
2000 Boxter - Sold
Old 03-27-2020, 07:02 AM
Agreed with the above, now that I think about it more. . It is good glue but Permatex or #M are prob a much better and more modern product.
Old 03-27-2020, 08:28 AM
l_turn9's Avatar
Thanks Guys! That's very helpful. In fact I'm pretty sure I have 3M and Permatex on the shelf -- so that makes things easier.
Stay Safe --
Larry
Old 03-27-2020, 10:37 AM
